05-04-2021, 06:30 PM | #1 |
Drives: 15 Camaro SS Join Date: Oct 2018
Fuel leak, need some ideas
So deep in this build and almost finished, but hit a snag. I replaced my fuel pump with a zl1 pump assembly. Had fuel to 1/4 tank and was able to get my old pump out through the floor without a mess. Installed the new pump amoung many other things and added a 5 gallon can of 93 to my tank. Woke up to a house filled with the smell of gas. Pulled my back seat and access door back off and found fuel all around the hold down ring. So its a brand new pump and brand new green oring seal. Guess i need to pull it back apart, but any ideas on how to safely get the fuel back out so i can pull the pump again?
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
05-04-2021, 06:43 PM | #2 |
Drives: G8 Join Date: Mar 2012
Are you sure it's not one of the fittings or a cracked line? I assume you primed the system and called it a day? If it's an unseated pump housing you probably wouldn't have been able to get the locking ring back on properly... And fuel sloshing while driving would show the leak.
Sent from my Pixel 4 XL using Tapatalk |
05-04-2021, 07:04 PM | #3 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
Pull fuel line a loose under hood. Switch key on and let fuel pump pump it out. Not sure on specifics
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
05-04-2021, 09:37 PM | #4 | |
05-04-2021, 10:00 PM | #5 |
Thought about that. Was going to take a large hose and see if i can clamp it around there somehow
05-05-2021, 06:20 AM | #6 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
Any chance you pinched the o ring?
05-05-2021, 08:08 AM | #7 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
If you are not pulling the tank, why do you need to remove the 5 gallons? Unless you get all of the gas out, the tank will still be full of vapors and that is what is the dangerous part, not the liquid.
05-05-2021, 08:43 AM | #8 |
This is really odd. Hoping its an easy fix once you figure it out.
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, RPM 5” CAI, Kooks Headers, Solo Cat Back, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
05-05-2021, 10:00 AM | #9 |
Maybe, was pretty darn careful though. I have never seen one leak like this
05-05-2021, 10:01 AM | #10 |
Because I did the trap door method to access the pump. The fuel was level with the opening of the basket. I installed the new pump assembly and added 5 gallons. If I knock the ring off, there will be 5 gallons of gas on my ground
05-05-2021, 10:03 AM | #11 |
I ordered another o-ring for the pump assembly. Going to have to pump out the gas through the feed line at the fuel rail I guess to lower the level 5 gallons. Curious myself. Maybe i missed some dirt down in there
05-05-2021, 10:18 AM | #12 |
10-4, I guess I should have realized there was more than just five gallons in the tank if the fuel pump was leaking at the o-ring.
05-05-2021, 11:01 AM | #13 |
Still crazy though, its all brand new. Got to pump this pig down when I get some time and its not raining. The poor girl is seeing its first time out in the weather. Wife is giving me crap about the fuel smell in the house lol
05-05-2021, 01:55 PM | #14 |
Drives: 2013 zl1 vert Join Date: Dec 2018
Can you jack up the passenger side and let the fuel go to the other side of the tank.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
