08-09-2016, 08:08 AM | #1 |
Drives: 2010 ABM RS camaro Join Date: Oct 2015
vararam intake with vmax icolator
is anyone running a vararam intake with the vmax icolator with double oem gasket does it fit or does it have to be modified plus is it still as effective. thanks
08-09-2016, 01:32 PM | #2 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
I believe you need longer bolts for it to work and the stock engine cover won't fit anymore.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
