JDP Motorsports
Old 12-12-2015, 03:32 PM   #1
pimpaluv
Drives: 2010 camaro 1ss
Recommended cam for a ls3 with a Maggie
It's about that time to invest into a blower cam. I'm sure there are forums that discuss this same topic. I also live in cali not to sure if it would matter when it goes into smog. I'm looking for dynos most of all. Alot of people talk the talk but no dyno to compare. Im looking into gain hp more than anything else but as a dd. Show me what you got!!
pimpaluv is offline   Reply With Quote
Old 12-14-2015, 12:07 PM   #2
Outlaw77
Outlaw77's Avatar
Drives: 2010 2SS/RS I.O.M. Camaro 6MT
I went with the LPE GT 14 cam. I know there are more aggressive cams out there but my local shop swears by them. Dyno sheets show gains from 525 rwhp to 590. When I got my cam installed and tuned it was really hot weather so heat soak was an issue. I thought about going back and tuned again in the fall or spring, not in the middle of summer.
Current: 2018 Charger SRT 392
Had a Cammed & Blown 2010 2SS/RS
Outlaw77 is offline   Reply With Quote
Old 12-14-2015, 02:40 PM   #3
smokum
smokum's Avatar
Drives: 2010 2ssrs
BTR stage 2 or 3. I have the 3 and like the chop. Makes gobs of torque down low and has a relitively smaller lift compared to others.
smokum is offline   Reply With Quote
Old 12-14-2015, 02:51 PM   #4
EDFHOBBIES
EDFHOBBIES's Avatar
Drives: 16 SS & 17 ZL1 Both Yellow
Send a message via Skype™ to EDFHOBBIES
I had BTR 3 very good!.. If your doing an off the shelf you can't go wrong with them.
You will see that there are 3 popular cams out there..
BTR Stage 3 PD
Lingenfelter GT9 well maybe they have a different now this was 1 1/2 years ago
Texas Speed
EDFHOBBIES is offline   Reply With Quote
Old 12-14-2015, 03:00 PM   #5
trans665
trans665's Avatar
Drives: 2010 2ss
I'm getting the. BTR3......hear real good things from. Ls trucks to caddy's to camaro and vetts
2013 auto ss..full bmr suspension..3800 stall...s475 turbocharger on 16 psi with 150 nitrous outlet plate...,BTR stage 3 turbo cam.....100% Methanol injection....LY6 6.0 iorn block ...
trans665 is offline   Reply With Quote
Old 12-14-2015, 03:10 PM   #6
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
That's my recommendation also. I know where you can get one
All the best,
Jared Royce
888.308.6007
Old 12-14-2015, 06:37 PM   #7
pimpaluv
What hp did you guys gain before and after? And how much boost was used?
Old 12-14-2015, 09:53 PM   #8
SannerRacing
SannerRacing's Avatar
Drives: 2010 1SS RS IOM
Cam
As a DD you need to ask yourself how much dose fuel economy play into your plan. But if that's not an issue a stage 4 CMS cam in a stroked ls3 making 700rwhp for now at 10.6 lbs of boost. Getting 7 mpg avg with this cam and engine combo and this is just an engine break in tune. Before this it was a stage 2 CMS cam with stock cubes and 13.7 lbs of boost making 714rwhp and getting close to 9mpg. This is all on e85 I tried 91 the tank before this and it really wasn't much better on mpg. So anyway there's something to think about.
Forged LS3 416ci, Maggie TVS2300 @ 13lbs boost, McCleod twin disc clutch, GForce 1320 nine-inch 389 gear ratio, Hurst line-lock, 750 whp 700 wtq
SannerRacing is offline   Reply With Quote
Old 12-14-2015, 10:06 PM   #9
smokum
smokum's Avatar
Drives: 2010 2ssrs
Not sure exactly but i made 721rwhp/740rwtq at 10psi on my 417. More torque than my street tires will take. You can probably expect about a 75-80rwhp gain. I just drove it a few weeks ago on an 800 mile trip and averaged 21mpg. Car is an m6.
Old 12-14-2015, 11:52 PM   #10
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
I just got my BTR Stage 3 PD cam today with all the other goodies
PerformanceHeartbeat Supercharger -BTR Stage 3 PD Cam -BTR Supporting Mods -CHE Rocker Arms -Roto-Fab Cold Air -VMaxx TB -Elite E2 Catch Can -NGK Trix7's -Squash Fuel System -FIC 1000 Injectors - JDP Clutch Res Relocation -Kooks LT's/Cat-less -Corsa 3" ZL1 Black Tip Exhaust-
Suspension1.25'' Front & 1" Rear Drop- BMR (Sway's, Toe Links, Trailing Arms, Front End Links, Upper Control Arm Bushings, Outer Trailing Arm Bushings)-FMT Solid Subframe Bushings
Brake's/WheelsPowder-coated Calipers-Goodridge Lines-Slotted and Dimpled Rotors-Hawk HPS Pads-OEM ZL1 10 Spoke Wheels (285 Front/315 Rear)
Nighthawk89 is offline   Reply With Quote
Old 12-15-2015, 07:22 PM   #11
pimpaluv
That's something to think about. It is my DD for work and I go a lot to Lake Elsinore which is 100 miles round trip. I've heard of loosing mileage going with a cam but 9mpg is nowhere were I want to be. Right now I'm avg 24-26mpg on stock ls3 with stock pulley on the Maggie.I could deal with 18-20mpg as I will be gaining some hp.
Old 12-15-2015, 07:27 PM   #12
pimpaluv
BTR sounds like the right choice as they have the kit ready to go!! My concern with be the mileage I would be getting after as it's my DD
Who will be doing the install and what are they quoting you if you don't mind me asking?
Old 12-15-2015, 07:29 PM   #13
pimpaluv
Sound like about right! Did you do the full kit or just the cam swap?
Old 12-15-2015, 07:50 PM   #14
2010SSRSM6
2010SSRSM6's Avatar
M.P.G's are directly proportional to the frequency you mash the go pedal. SannerRacing and I have (well had until he went to 416 and I had a failure) and we were off about 4-5 m.p.g on average.
We are both on E-85 with a boatload of other mods on top of the cam so IF you stay out of it and stick with boost that will allow you to use the original injectors and fuel pump, you should be able to stay around 21-ish. When you upgrade injectors, fuel pump (or twins like us) you burn through your take a lot quicker.
Cam, Springs, Lifters, install and Tune runs about $3000 in Temecula @ CMS. It may be more, but that's a good ballpark.
