06-16-2017, 12:38 PM | #1 |
Drives: Black ss Join Date: Jun 2017
IAT Breakout
Just curious if I get a breakout kit install will it need to be retuned? and why!
Thanks in advance |
06-16-2017, 08:06 PM | #2 |
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust Join Date: Sep 2014
I moved my iat, no tuning required for moving it.
06-16-2017, 08:38 PM | #3 |
Drives: 2009 ZR1 Join Date: May 2010
A reason to breakout the IAT is for meth use. The IAT is in the MAF from the factory. You should not have meth pass over the MAF wiring as it will cause issues. If you break out the IAT, you move it after the MAF; either mount it in the intake or in the intake tube between the MAF and TB.
This allows you to get benefit of the engine "seeing" the cooling effect of the meth which you can tune for or just leave the tune as is and the meth is just a safety factor. If you aren't using meth, it probably isn't worth moving the IAT. Another reason would be if you go with a MAF-less speed density tune and get rid of the MAF sensor setup altogether. |
06-16-2017, 08:41 PM | #4 |
'It's an experiment'
As long as the new sensor has the same resistance scale/curve, no retune will be needed.
The scales, however, are in the tune: http://www.camaro5.com/forums/showth...385577&page=42 I did the breakout for my LSA kit in order to read the lid's sensor, thus we had to rescale it. Post 577, 578, 579, 580 goes through what I had to have done along with where the scales are. Just to give you an idea if you have a different sensor scale...
747 RWHP 794 RWTQ
06-16-2017, 10:49 PM | #5 | |
10-08-2017, 01:11 AM | #6 |
WHPLSH
Drives: 2010 SS Maggie,ARH,Meth,AFE Coilove Join Date: Mar 2010
Does anyone know the right sensor to get that has the same resistance scale/curve and which harness is best the casper one which is 20$ no sensor or Teds which is 35$ and it looks like you have to do some cutting and soldering but comes with a sensor Thanks
10-09-2017, 01:13 AM | #7 |
Sensor: 12614717
Casper's: http://www.casperselectronics.com/ca...&search=108165 |
10-09-2017, 10:04 AM | #8 | |
The Plug and play jumper harnesses are Sweet but adds extra clutter under the hood. Ted.
www.jannettyracing.com
08-14-2019, 09:30 AM | #9 | |
Dan
Drives: 2010 Camaro 2SS IOM Join Date: Nov 2013
Ted, the IAT wires are the tan and light blue wires right? Thanks, Dan
Dan
2010 IOM SS YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust http://www.camaro5.com/forums/showth...&highlight=ysi |
08-14-2019, 11:16 AM | #10 |
Yes...
747 RWHP 794 RWTQ
08-15-2019, 03:21 AM | #11 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
Could get another oem MAF and just use the IAT circuit?
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
