11-19-2019, 10:16 PM | #1 |
Drives: 13 1LE 1SS/05 ZX10/02 Silverado/14 Join Date: Nov 2014
eBay cutouts/diverters
I just got a set of dual valve cutouts/diverters has any one used these and does anyone have any install pics. And how did you run your wiring for those who has done the install.
02 Stepside Silverado
05 ZX-10 13 1LE 14 Nightrod Special |
11-20-2019, 12:07 AM | #2 |
Drives: 2013 L99 Join Date: Jan 2019
They will develop an annoying rattle in a few months and you will hate them and all the miserable time you spent installing them
11-20-2019, 12:18 AM | #3 |
Drives: 13' 1LE Join Date: Apr 2012
LOL
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
11-20-2019, 11:49 AM | #4 |
Is that what happened to yours? You got pics?
11-20-2019, 11:52 AM | #5 |
11-20-2019, 03:20 PM | #6 |
Drives: 2010 Camaro Join Date: May 2014
11-20-2019, 04:23 PM | #7 |
Drives: 2010 IOM 2ss/RS Join Date: Sep 2009
I bought a cheap one, worked fine for quite awhile, then it broke and I replaced it with another that's still doing fine. I wired it up by the stick shift I believe. remote works no problem.
Turbonetics running 8lbs boost at 700rwhp tuned by Hi Rev, installed by K&M w/cat-muffler delete, ACS splitter, Fesler GFX, MPD1 spoiler, Custom painted Rally stripes, Cordon CR1 wheels 275/315s, Hotchkiss comp sways and end links, Barton shifter
11-21-2019, 12:53 AM | #8 | |
Did you wire it to a switch or just use the wireless box they sent with it?
11-21-2019, 12:58 AM | #9 |
Hey op don't stress over this. Guy just made a funny comment how bad it could be. Happens often with some cheap car parts. Happened to me more than a couple of times. Now I pay to play.
13' 1LE
11-21-2019, 09:01 AM | #10 |
Maybe this will help you then. It’s the NOWEEDS install instructions. Perhaps you can use the same hot wire under the drivers seat etc..l
https://cdn.shopify.com/s/files/1/07...?1032098857432 |
11-21-2019, 04:45 PM | #11 | |
I have read that before I wish I could use their switch.
11-24-2019, 12:29 PM | #12 |
Iwanta, when you get these installed would you mind updating the thread with some pics or video? If you have the time, of course.
11-24-2019, 04:10 PM | #13 |
Sure thing I’m going to try to install them tomorrow a long with my new diff
01-17-2020, 02:22 PM | #14 |
So tomorrow turned into Next year lol but I got them installed and if they last a year then it’ll be well worth 177 for the pair. I’ll get pics a video later if you want.
