01-31-2017, 01:53 PM | #1 |
L99 Cam Help
I am new to this forum and was hoping someone could point me in the right direction, possibly a thread already containing this topic . I have a 2010 L99 SS Camaro and im looking into a Cam. I have done a little research and was drawn toward a VVT cam rather than doing an LS3 conversion and LS3 cam. My question is what is the difference between the TSP VVT , VVT-2, VVT-3, and VVT-4 cams. Also im trying to find out what all I need to purchase before setting an installation/tune appointment with my local speed shop here in Tampa.
Mod I have now, (not much) K&N CAI Ported throttle body BBK long tube headers w/HF cats Dyno tuned by Phil @ Tampa Tuning Any help is greatly appreciated, Thanks guys. |
01-31-2017, 02:03 PM | #2 | |
Drives: Black L99 2SS/RS Join Date: Mar 2014
Here's the TSP VVT cam in action a good indication of how they differentiate. http://www.camaro5.com/forums/showthread.php?t=481873 http://www.camaro5.com/forums/showthread.php?t=296878 Below is a good link for complete packages. (One of many) http://shop.gwatneyperformance.com/g...tcamshaft.aspx They include complete cam kits, it's always HIGHLY recommended you upgrade the lifters. There's debate on things like trunion, upgrading the oil pump and upgrading timing chain. Off the top of my head, I believe L99's are equipped with pretty strong oil pumps and an upgrade isn't exactly necessary. So to sum things up, get the complete kit from the link above and then you can consider going a step further like mentioned... timing chain, oil pump... perhaps even stronger lifters like these. https://www.briantooleyracing.com/jo...lsr-32584.html The L99's from the factory have really crappy AFM (active fuel management lifters) that are a nightmare waiting to happen for any cam upgrade. So my personal recommendation is go have a shop tear your car apart once the first time, skip no steps, don't go cheap and you wont have to worry about it again! |
01-31-2017, 02:36 PM | #3 |
Awesome! That's exactly what I was looking for. Thanks taking time out of your day to help me out. I'm excited for what's to come!
01-31-2017, 02:36 PM | #4 | |
No problem! Above is the link for the actual cam you're looking for, complete with the entire package. |
01-31-2017, 03:10 PM | #5 |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
With the VVT cam, we can still delete the DOD oil control junk and lifters, right?
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
01-31-2017, 03:40 PM | #6 | |
It may help when thinking about all of this to try and separate your linking of the DOD/AFM with the VVT. They are 2 separate systems, with the VVT being what you want to keep.
01-31-2017, 07:02 PM | #7 |
PaPa Smurf
Call GPI. Gwatney performance
2022 Rapid Blue SS 1LE
02-01-2017, 07:11 AM | #8 |
I really appreciate all the help guys I didn't expect to get a response so quick. I will be going with Texas speed VVT cam definitely. I'll give them a call this week and see if I can get something in the works.
02-01-2017, 10:53 AM | #9 |
Drives: A boring sedan Join Date: Jan 2016
Before you do that I would recommend you still contact GPI...their smallest cam still makes 450 WHP with exhaust and unmilled heads.
02-01-2017, 11:59 AM | #10 | |
Drives: Z06 Join Date: Oct 2009
Take a look at our VVT2. It picked up 114hp over stock and offered a really broad range of power. On the dyno pull you can see it picks up across the board. We have spent tons of time and hundreds of dyno pulls making these new camshafts. Our lobes are very valvetrain friendly and our camshafts are more accurate than any other cam I've seen. We have looked at many other manufacturers and haven't seen any other cam even come close in accuracy.
02-01-2017, 12:26 PM | #11 | |
Drives: LSX FTW Join Date: Feb 2016
Take a look at their SS1 VVT cam, it outperforms bigger grinds from other companies.
#Gapped
Tags |
cam, l99, tuning |
Thread Tools | |
