11-08-2019, 06:06 PM | #1 |
Drives: 2012 SS Join Date: Feb 2016
Valve train opinions
Looking for opinions on my next upgrade. This winter I plan on doing a cam swap on my LS3. I have been slowly acquiring parts over the last few months. Would like opinions as to whether I am missing anything.
So here we go, TSP 225/236/113 cam, pushrods, springs with titanium retainers. Melling oil pump, C5R chain, LS2 chain damper. (would like opinions on this vs the LS3 tensioner) I have the comp trunion upgrade, but after hearing the failure rate, I am hesitant about using them. Was thinking bushed rockers? I realize this is a small cam & I intended it that way. I daily drive it quite alot. I Just want to have as good of valvetrain that is reasonably possible. Thanks in advance.
2012 2SS/RS 6speed, Howards asa cam on 113lsa Stainless works LT's, NPP exhaust, Z28 Cai, 3.91 gears. Tuned by Blue Thunder 2 racing Lubbock Texas.
11-08-2019, 06:23 PM | #2 |
Drives: 2011 Chevrolet Camaro ss Join Date: Apr 2019
Lingenfelter has a beehive kit that they recommend for anything up to .660 lift, i believe its what they use on ther GT12 cams. Seems like best for dollar though is the BTR .660, i myself am looking for a spring kit since i have a GPI SS2 which has a tad bit lift more than the TSP cams.
11-08-2019, 07:12 PM | #3 |
Drives: 2010 Camaro 2SS/RS ABM 6M Join Date: Jul 2017
I went with the TSP stage 3 cam, pushrods and .660 spring kit, and have been super happy with it all. I just went stock replacement melling, and I DID do the ls2 tensioner for (sure recommend) Since I sent in the heads for porting I did my lifters too. A couple showed signs of scoring from debris, and cam matched. Definitely inspect the stock cam lobes when it comes out. I chose to not look at my cam bearings and just stabbed the new one in with plenty of assembly lube I only spin to 7k though (7200 limiter). May have considered a different spring if I was turning faster but for my long term goals, this is a perfectly fine spring I think.
I went with solid bushed trunion and don't regret it. I went with the Powell kit from eBay (will link below) and no issues so far. CHE seems to be the top brand, but I don't think you can go wrong with any of them as long as they are solid bushing. I think this is at least part of why my valvetrain is so quiet. https://www.ebay.com/itm/Chevy-GM-LS...AAAOSwHZhbLEQo
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
11-09-2019, 01:55 AM | #4 |
I would definitely replace that LS3 timing tensioner while you are in there. The LS2 dogbone is so inexpensive and rugged there really is no reason not to use it, imo. I have read too many posts here and elsewhere of people opening up their front cover only to see the LS3 tensioner arm snapped and/or missing. There is a tension spring behind the arm that can get lost and find its way behind the cam sprocket or elsewhere.
I recently rebuilt my new engine and made sure to pull out that flimsy LS3 tensioner and swap for the LS2 dogbone. I just prefer to not have moving parts somewhere that does not need it. They work differently though by design. The LS3 tensioner actually adds tension to the chain while the LS2 version simply disallows extended chain flex or 'slapping'. But plenty of people have had no issues with the LS3 version, it's simply my opinion.
11-09-2019, 07:49 AM | #5 |
old school chevy rodder
Head gaskets, new lifters, new tty bolts, some RTV for the ends of the timing cover with all the gasket kit and the three bolt timing gear, a pushrod measuring tool. I break in with driven racing br30 and use ls30, and use a 8620 core.
11-09-2019, 09:52 AM | #6 | |
11-09-2019, 01:16 PM | #7 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Your build sounds a lot like mine except for the cam, I’m saving for a set of Johnson lifters from GPI.
Orange Krush II
11-10-2019, 12:24 AM | #8 | |
Ahh, so you know the old rule... Never look at your cam bearings. If you do, they will be bad.
