Old 08-22-2016, 01:53 PM   #1
MyLocalDJ
MyLocalDJ's Avatar
Drives: 2015 2LS
Aftermarket Heated Seats - Need Seat Connector Pinout 2015 LS
I bit the bullet on new Katzkin leather seat covers and bought seat heaters to go along with them. Original seats are cloth and no heaters.
The heater kits from Katzkin have the heater harness, relays, and switches with them. What I am thinking is that I should be able to just connect into the power feed under each seat. I believe each seat connector has a power feed for the back heater and another power feed for the seat heater. If so, does anyone know what pins these are or what colors they are and if this would work?
I wanted to just change out the dash control panel but finding one for a 2014 or 2015 at a decent price has not worked out. Although the panels look the same, the earlier models are a different P/N and will not work from what I have been told.
Would appreciate any info that may be available.
File Type: pdf carbon_seat_heater_installation_guide.pdf (834.7 KB, 70 views)
MyLocalDJ is offline   Reply With Quote
Old 08-26-2016, 08:10 AM   #2
MyLocalDJ
MyLocalDJ's Avatar
Drives: 2015 2LS
Old 08-28-2016, 06:09 PM   #3
Zl1TopLess
Zl1TopLess's Avatar
Drives: 2013 Victory Red ZL1 M6 Vert
I think they are logic controlled anyway, it uses can buss. Just add a button to each seat and call it done. I did that on my daughters G6.
2013 ZL1 M6
Roto Fab CAI, Kooks Long tube Headers with catless connection pipes, 90mm Ported throttle body to match ported supercharger snout. 2.55 upper pulley, Roto Fab intercooler tank, ID 850 injectors, 9.5 mm wires, Custom 93 octane tune. 600 whp. Hotchkis coils.
White Collar Grease Monkey
https://www.youtube.com/user/gjodexter
Zl1TopLess is offline   Reply With Quote
Old 08-29-2016, 08:49 AM   #4
MyLocalDJ
MyLocalDJ's Avatar
Drives: 2015 2LS
Thanks, I was already starting to lean that way. I was hoping to tap into the main power under each seat and then when I changed to an aftermarket dash panel for a new sound head unit I could have potentially leveraged the functions then. The factory panel was like $500. Crazy...
Old 08-29-2016, 05:01 PM   #5
camaro2ss/rs
Drives: 2ss/rs
have to ask what will this cost you when all said and done..
camaro2ss/rs is offline   Reply With Quote
Old 08-30-2016, 12:14 PM   #6
MyLocalDJ
MyLocalDJ's Avatar
Drives: 2015 2LS
Leather custom seat covers from Katzkin Canada Seat Covers: $1143.96
Included the heated seat kits (upper and lower)
with relay and switch harness. Shipping included. Had them on my doorstep within a week.
Seat and Heater Installation: $450
That is assuming to just use their installation kit and not trying to adopt the factory setup. There was also a big range in cost on installers from one shop to another.
Install going in tomorrow. I will post up afterwards.
Old 08-30-2016, 12:39 PM   #7
camaro2ss/rs
Drives: 2ss/rs
[QUOTE=MyLocalDJ;9285606]************************
good luck
