07-07-2020, 09:27 AM | #1 |
Drives: 2013 camaro ZL1 Join Date: Oct 2019
2013 ZL1 header fitment issue
Yesterday I installed a set of kooks LTs 1-7/8” and they touch the plastic aero piece that covers the bottom of the engine. Has anyone else had this issue? Do I remove the plastic piece? Cut out around the headers? Leave it and just let it melt? I don’t want to burn it to the ground...
Sorry if this has been covered before |
07-07-2020, 09:48 AM | #2 |
Drives: 2012 ZL1 Join Date: Apr 2015
The choice is yours, those are all options. I just left mine off, some people cut around the header, I would definitely not leave it to melt away!
2012 ZL1 preproduction car #13 ROTO-FAB intake / IC reservoir , 2.85" upper , ported inlet |
07-07-2020, 11:07 AM | #3 |
Drives: 2013 HWSE Indy Festial #26 Join Date: Mar 2011
Cut around it. 14-15's had that notched out by the factory for this very reason.
There are only so many days in your lifetime. So get out and drive your Camaro...
Dan |
07-07-2020, 11:20 AM | #4 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
Tin snips, Jigsaw, dremel. There is sort of an outline to follow. Also I ran a torch over the fiber material to stop it from shedding. |
07-07-2020, 04:43 PM | #5 |
I appreciate the quick responses guys. I ended up just taking it off.. maybe will notch it out later on. Wanted to get the car started so I could do I heat cycle and re-torque the bolts
07-08-2020, 05:58 AM | #6 |
Happy_Dan
Mine is notched out around headers. Looks clean
07-08-2020, 06:55 AM | #7 |
Drives: Camaro ZL1 Join Date: Jan 2016
Notched mine also. Removing it will not only mess with the aero but also dirty up the bottom of the car.
07-08-2020, 08:41 AM | #8 |
Happy_Dan
Of course if your oil cooler or anything else is leaking, it collects on the cover.
07-10-2020, 10:03 PM | #9 |
Drives: 2013 Chevrolet Camaro ZL1 Join Date: Jul 2019
Connection pipe
I had my mechanic install my headers a couple years ago with off road connection pipes. Problem is, one of my exhaust clamps broke during a dig and when i got home to park the car it had a dent in connection. So i have tried to button it up with a different style clamp but i can still hear the exhaust leak and I am having trouble finding a replacement piece. Anybody know where i could find any? 1 7/8" TSP longtube headers to OEM catback.
07-10-2020, 10:42 PM | #10 | |
Harbor Freight 2.5 od pipe expander, if you have a heavy plastic mallet you can shape while using the expander if it’s really bad. |
07-10-2020, 10:43 PM | #11 |
07-11-2020, 05:12 PM | #12 |
Drives: 2013 Camaro SS Join Date: Feb 2017
Anyone know what this part is called and if it would fit an SS
2013 Camaro SS
Kooks Headers Vararam DRX 1le Differential 3.91 Bo White throttle body Magnaflow Competition Exhaust 12.391 112 MPH 10/05/19 |
07-18-2020, 11:35 AM | #13 |
i just notched around when I installed my headers. Took me about 10 minutes per side. Keep underside looking clean and factory looking. When I do an oil change just remove those few bolts and lower it down don't have to remove all the way.
FBO. Cammed. Flex fuel.801whp/741wtq on e85
