Old 10-24-2020, 06:34 PM   #1
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
Drives: Chevrolet Camaro SS
High Idle While Coasting
Background: I bought my SS with a BBK 95mm TB on it and had continual CEL issues. Just got a LS3 stock TB and swapped it out. Went for my first drive just now.
When I throw it into neutral coasting into a stop sign the engine holds at 2,000 rpms until I come to a complete stop. Didnít do this before.
What is causing this?
2014 SS LS3/LSA Supercharger, ID 80# injectors, LT Headers, BBK 95mm throttle body, Roto-Fab CAI, VaraRam, Elite E2 catch can 160 Thermostat, HP Tuners, JL Audio system.
Valkyrie14 is offline   Reply With Quote
Old 10-25-2020, 03:09 AM   #2
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS LS3 Swapped A6
It may clear up with more driving. I am not sure of the idle or TPS relearn procedure on these cars. It may take several ignition and drive cycles.
2010 CGM Camaro 2SS LS3 Swapped A6 - GPI LS3 SS1 .647/.638, (224/237, 112 +4) on CamMotion 8620 core, Melling HV 10296 oil pump, CHE bronze trunnion upgrade, stock heads milled .015, TSP long tube headers (W/Catless Off-road Pipes), FlowMaster Outlaw axle back/X-Pipe, Stage 2 Ported Throttle Body, Vararam OTR CAI, Mike Norris Gen 2 catch can + GM 1LE clean side separator, 160ļ thermostat - Megan Racing adjustable coilovers, Firestone Firehawk Indy 500s - Tuned by Ryan @ GPI via HP Tuners
Old 10-25-2020, 06:13 AM   #3
Rich2010
Drives: 2010 Cyber Gray LS3 SS/RS
Mine does it too, but the minute I clutch in itíll drop to idle.
2010 Cyber Gray LS3-BTR stage 4-480/428 RXT and 3.91ís
Rich2010 is offline   Reply With Quote
Old 10-25-2020, 06:45 PM   #4
RupertPupkin
Drives: 2014 Camaro SS 1Le
Mine did that, but it ended up having a cracked spark plug.
14SS 1LE 2SS/RS/Recaros|Tick Polluter Stg-3|E85
LS7 Lifters|BTR Springs|Speed Engineering LTs|Muffler Mod|ECS 1500|DSX Aux Pump|DSX Flex Fuel Sensor|FIC 127#|ATI Balancer|DashLogic| McLeod RXT|BMR 1.4 Springs|MightyMouse Wild|AEM WideBand|AEM BoostGauge|ZL1Addons Splitter|VA Sideskirts|POWER : 737whp/635trq
RupertPupkin is offline   Reply With Quote
Old 10-25-2020, 08:39 PM   #5
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2014 ZL1
Throttle body relearn procedure may help?
2014 Red Hot #1503 | TBD SAE | RotoFab | 28% OD | GP Tuning 2.5 Cam | 2" TSP LT's | JMS BAP | ID850 | TR7IX | MSD Wires | APEX Catch Can | Metco Breather | Monster LT1-S Triple | C&R HEX | RotoFab Res | Racing Brake Rotors | Self-Tuned w/ HPT
RobZL1 is offline   Reply With Quote
Old 10-25-2020, 10:09 PM   #6
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
I will try this in the morning.
Old 10-26-2020, 12:09 AM   #7
Vegas Bound
Drives: 2013 Sparkly Red One
I solved it with a 4L80e swap.
Lots of bolt on stuff
Bests in each category
1.36 - 60'
6.29 - 1/8 mile
10.18 - 1/4 mile
Vegas Bound is offline   Reply With Quote
Old 10-26-2020, 09:32 AM   #8
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Check your tune for the TB area calculation. You dropped in TB size => airflow into the engine is now skewed slightly. Definitely tune related though.
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 10-26-2020, 11:29 AM   #9
NXTLEVL
NXTLEVL's Avatar
Drives: 2010 Camaro SS/RS Twin Turbo LSX454
Mine does the exact same thing. Nick Williams 102mm. I've got RDP doing a tune on it now to address this and other things. I'll update this thread once he's finished.
NXTLEVL is offline   Reply With Quote
Old 10-26-2020, 11:34 AM   #10
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Sometimes that is in the tune to keep the rpms from dropping too fast and falling past idle causing a stall issue. Mine is tuned this way, when I clutch in the rpms drop to about 1400rpm for a few seconds before falling to 800rpm
Greenhornet2 is offline   Reply With Quote
Old 10-26-2020, 09:37 PM   #11
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
So this will either support the tuning answer or mean something else. When I press in the clutch the rpms go down to normal.
Old 10-26-2020, 10:30 PM   #12
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
Can a GM TB be ported to 95mm?
I could put my BBK TB back in get my GM TB ported out and then it would be equal.
Old 10-26-2020, 11:04 PM   #13
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2014 ZL1
Then it's in the tune. There are in-gear and neutral/park rows in the airflow tables and also the spark tables. I incorrectly assumed the tune had been modified for the TB change- my bad.
And for what it's worth, if you spend enough time to get it right, you don't need to have the idle hang to prevent a stall. You can tune the throttle blade and the spark to properly catch the idle at the targeted idle speed under all conditions. That 1400 thing is not a necessity, it can be improved to drop straight down to idle rpm.
Old 10-26-2020, 11:43 PM   #14
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
That makes sense. I wonít pretend to understand the technical points of the explanation. I use a tuner, but want to learn how to use my HP tuner. I get intimidated each time because of all of the terminology I am unfamiliar with. How difficult would it be to tune for the GM TB?
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
