Old 10-25-2020, 11:43 AM   #1
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2013 Camaro 2SS 2015 LaCrosse
Tranny cooler lines.
Which tranny cooler line is the return line? Driver or passenger side? The posts are confusing I need a definitely positive answer. Thanks.
The thing that sucks, long lumpy thing, little silver thingys, chrome tubes, dials, wires, zip ties, lots of bolts, gaskets, a fat belt, springs underneath, springs inside, round thing with fluid.
TheFlyingBananaSS is online now   Reply With Quote
Old 10-25-2020, 12:13 PM   #2
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
Personally I dont think it matters. But looking at my service manual for the 2014 model, the passenger side is the inlet.
Mods - GPI Tune (Rhino79), SS2VVT Cam & RodMod Intake, CHE Trunion Upgrade, Holley Fuel Rails, B&M Transmission Pan, JRE Trans Dipstick, Circle D 3600 Single Disc Converter, ADM CAI, Scoop & Trans Cooler, Kooks Headers & Cats, Solo Cat Back, Elite Catch Can, Z28 Grill, Aero & Body Package, BMR 1" Lowering Springs & all the BMR Goodies in the rear, Hendricks Offset Diff Bushings, AFE Solid Subframe Bushings, MRR228 Wheels, Eaton Tru-Trac, Hurst Roll Control.
Ashen 6.2 is offline   Reply With Quote
Old 10-25-2020, 01:20 PM   #3
TheFlyingBananaSS
Again..... SPECIFIC PLEASE. Which is the RUTURN line? Inlet tells me nothing. Inlet to what? The tranny? The cooler? I need specifically which one it is. This is important.
Old 10-25-2020, 02:18 PM   #4
TheFlyingBananaSS
We found it. Search function is very strange on here.
Old 10-25-2020, 02:21 PM   #5
Silver14
Drives: 2014 SIM 2SS
Good! What was the answer in case someone else ever lands on this post in a search?
Agreed about the search within the forum. I have much better luck with a Google search of this site by using "insert search terms here" site:camaro5.com
Silver14 is offline   Reply With Quote
Old 10-25-2020, 02:35 PM   #6
Ashen 6.2
Ashen 6.2's Avatar
Sorry about that.. I had cooler inlet on my mind for some reason..
Old 10-26-2020, 12:14 AM   #7
Vegas Bound
Drives: 2013 Sparkly Red One
I have no idea what a RUTURN is.
Lots of bolt on stuff
Bests in each category
1.36 - 60'
6.29 - 1/8 mile
10.18 - 1/4 mile
Vegas Bound is offline   Reply With Quote
Old 10-26-2020, 10:45 AM   #8
Pearlj10
Drives: 2011 Camaro 2LT
Driver’s side is the return line.
Pearlj10 is offline   Reply With Quote
Old 10-26-2020, 10:52 AM   #9
TheFlyingBananaSS
Correct sir! You win the internet. For those who are not familiar with transmission lines, one line is a FEED line to the stock cooler and the other is the RETURN line back to the transmission after going through the cooler. The reason this is critical is you want the fluid to get the thermal cooling from the fluid to fluid cooler first, before it gets secondary cooling from the air to fluid cooling which is not as efficient as fluid to fluid.
Old 10-26-2020, 04:27 PM   #10
Ashen 6.2
Ashen 6.2's Avatar
So you added a secondary cooler for the transmission?
Old 10-26-2020, 04:29 PM   #11
TheFlyingBananaSS
With a stall converter it's a must have. Heat is always your trannys enemy.
Old 10-26-2020, 04:43 PM   #12
Ashen 6.2
Ashen 6.2's Avatar
Agree with the heat is your trannys enemy. I have a 3600 stall and an external cooler only (bypassed the radiator cooler/heater). My trans temps have never gone above 180 even after 8 pulls on the dyno at GPI or 9 passes at the track in one evening.
Interested to hear how your temps are once you get things settled in. Well, that and the next dyno session along with your track event.
Old 10-26-2020, 11:16 PM   #13
Pearlj10
Hey Ashen 6.2,
Which tranny cooler did you go with? I installed a Derale 13401 but live in Phx and the temps would climb to 200 degrees when it was hotter than $&#! in the summer (110+) after a few hard runs. In hindsight, I wish that I’d installed a bit larger cooler. Thanks
Old 10-27-2020, 07:47 AM   #14
TheFlyingBananaSS
You've got an excellent cooler if it's a stand alone and keeping things under control
Looks like Thursday will be a rainout. Rain date is Nov 5.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
