Old 10-26-2020, 09:25 PM   #1
Roamer63
Roamer63's Avatar
Drives: 2014 camaro 2ss/rs
Where can I find these zip ties?
I would like to replace several of these stud stand off wire ties. Can't seem to find anything on the web. Little help please.
Roamer63 is offline   Reply With Quote
Old 10-26-2020, 09:36 PM   #2
InFiD3ViL
InFiD3ViL's Avatar
Where exactly is that located? What is it holding down?
2010 CGM Camaro 2SS LS3 Swapped A6 - GPI LS3 SS1 .647/.638, (224/237, 112 +4) on CamMotion 8620 core, BTR Platinum .660" Dual Spring kit w/titanium retainers, CHE bronze trunnion upgrade, stock heads milled @ .015, Melling HV 10296 oil pump, TSP long tube headers (W/Catless Off-road Pipes), FlowMaster Outlaw axle back/X-Pipe, Stage 2 Ported Throttle Body, Vararam OTR CAI, Mike Norris Gen 2 catch can + GM 1LE clean side separator, 160º thermostat - Megan Racing adjustable coilovers (lowered 1.75"), Firestone Firehawk Indy 500s - Tuned by Ryan @ GPI via HP Tuners
InFiD3ViL is online now   Reply With Quote
Old 10-26-2020, 10:41 PM   #3
Roamer63
Roamer63's Avatar
That one is holding down a ground cable under the hood. ( easy to take a pic). There are several more in the trunk/batt. area that I would like to replace.
Old 10-27-2020, 04:39 AM   #4
sdynak
Drives: 2010 1SS
Google search stud mount ties and look at images.. there are options.
Here is a similar Amazon Prime if you were in a hurry.. Worst case if you want OEM I'm sure the dealer could order them.
https://www.amazon.com/HellermannTyt...%2C174&sr=8-24
Or these
https://www.amazon.com/Panduit-PLST4...%2C174&sr=8-15
2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
sdynak is offline   Reply With Quote
Old 10-27-2020, 07:44 AM   #5
demonspeed
Not Afraid Of The Wall
demonspeed's Avatar
Drives: Camaros
You could also just get it from the dealership. At least just get the part number and I’m sure you’d find a pile cheaper
2013 1LE
a little bit of this and a little bit of that
Past Camaros: 02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z
demonspeed is offline   Reply With Quote
Old 10-27-2020, 08:01 AM   #6
Roamer63
Roamer63's Avatar
Thank you Sydnak. A little pricey but they would work. However that may be cheap compared to what the dealer would charge.
Old 10-27-2020, 08:54 AM   #7
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
Try looking at these - https://www.mcmaster.com/cable-ties/...-cable-ties-6/
or these - https://www.amazon.com/Gardner-Bende.../dp/B000BOE0TM
Mods - GPI Tuned, GPI SS3 PD Cam, Mag Heartbeat, ZL1 Fuel Pump, ADM FPCM, DSX Aux Pump, Soler Performance PTB, Circle D 3600 Triple Disc, RPM 5” CAI, Kooks Headers, Solo Cat Back, Z28 Grill, Aero & Body Package, BMR Motor Mounts, 1" Lowering Springs & all the BMR Goodies in the rear, Hendricks Offset Diff Bushings, AFE Solid Subframe Bushings, MRR228 Wheels, Eaton Tru-Trac, Hurst Roll Control.
Ashen 6.2 is offline   Reply With Quote
Old 10-27-2020, 09:01 AM   #8
mikeman
Banned
Drives: 2015 Camaro
Those look like the same wire tie downs inside the trunk/spare tire well that hold the battery wires/rear wiring harness against the body.
mikeman is offline   Reply With Quote
Old 10-27-2020, 10:17 AM   #9
Roamer63
Roamer63's Avatar
Thanks guys. This forum has been very helpful.
Old 10-28-2020, 09:08 PM   #10
oldman14ss
Drives: 2014 1ss camaro
yes these folks are great! I've listened to the voice of experience on this site more than you can imagine. these guys have taught this old dog new tricks for sure.
oldman14ss is offline   Reply With Quote
Old 10-28-2020, 09:24 PM   #11
InFiD3ViL
InFiD3ViL's Avatar
I have searched far and wide over the last few days as a result of this thread (It's a weird hobby), but cannot find these exact GM cable tie downs. Maybe better luck would be found at a GM dealership or body shop, which I did not try. Thankfully due to some of our other members we now know that there are suitable alternatives. This isn't so much an issue now as it will be in the future, when someone is trying to faithfully restore their 5th gen to exact factory specs. Luckily, 3D printers should be amazing in 20-30 years!
It is a possibility that these connectors are available only with the purchase of their respective master part. For example, I learned that if you purchase a new OEM negative or positive battery cable, it comes with these cable ties already attached, perfectly aligned so they can easily connect to the existing studs/anchor points. I saw this on several sites. But none of the parts sites actually list or catalog the cable ties individually, only as part of or included with their master part. Thanks again GM!
Old 10-29-2020, 06:16 AM   #12
Ashen 6.2
Ashen 6.2's Avatar
I am the same way sometimes! lol
Here is another one I found and looks very close to what GM uses.
https://www.ebay.com/p/1751570248 - Im not sure if this is the size you need though.
Avery Denison is the mfg and here is a link to their catalog - https://fastener.averydennison.com/c...%20Rev%20A.pdf
Old 10-29-2020, 07:44 AM   #13
Roamer63
Roamer63's Avatar
Thanks again guys. The ebay ones look good Ashen. Once you pull the O.E. off, they're pretty much done. I'd like to replace them with O. E. I need to talk to my local dealership and see what they say.
Old 10-29-2020, 09:15 AM   #14
Caddytech112
Drives: 2013 2ls camaro
Auveco sells factory clips, ties, connectors ect. Check their site they will have it.
Caddytech112 is offline   Reply With Quote
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
