05-16-2018, 03:13 PM | #1 |
Drives: '11 SGM 1LT/RS, '02 SOM Firehawk Join Date: Jan 2014
Clutch safety switch
Does the V6 manual have one? I assume it must.
I got in my 2011 this morning and tried to start it. I got nothing. I noticed the DIC is saying, "Please press clutch pedal to start engine" or something like that. It's got a pic of a foot pressing a pedal. I was pushing the pedal. I've tried it several times, and it's not registering the pedal as being pushed. I figured, "Ok. The safety switch is shot. No big deal." However, I can't even find a part for it. I haven't seen any threads about a similar issued, nor any info on replacing it. That's what I'm looking for. Is the part called something different? Is it just a plug-in part or is there more to it than that?
Yippee38
05-16-2018, 04:06 PM | #2 |
Drives: 2009 ZR1 Join Date: May 2010
The cars have a clutch pedal position sensor.
https://www.camaro5.com/forums/showthread.php?t=391244 |
05-16-2018, 09:22 PM | #3 |
Thank you! Apparently, I got the name of it wrong.
Yippee38
05-22-2018, 12:20 AM | #4 |
Drives: 13' 1LE Join Date: Apr 2012
I had mine cancelled by my tuner because I run a pedal stop..thatll solve it
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
Thread Tools | |
