Old 06-28-2013, 11:30 PM   #1
rajgopal2rajesh
Drives: 2LT AGM RS Dual Mode Exhaust
Mylink is not working after installing M2W controller on 2013 2LT
M2W is really working at it peaks.
but, MyLink and Also the lights at fan/temp are dead.
Do anyone of you come accross this issue b4?
Any suggestions?
rajgopal2rajesh is offline   Reply With Quote
Old 06-29-2013, 05:50 AM   #2
SnowVert
SnowVert's Avatar
Drives: Inferno Orange 2013 SS/RS LS3 6M
I have the M2W controller in mine and don't have any trouble. However when I installed, it, the instructions were a bit off. I don't recall what wasn't working correctly as I installed it the first week I had the car back in August last year, but it may very well have been mylink. There was one of the fuses that you removed that needed to then be put into the M2W controller (there was one fuse in the M2W controller if I recall correctly, but there is another slot just below that that is for one of the fuses that you remove for the install). Once I plugged that fuse into the M2W controller, everything worked fine.
Let me know if this helps.
With this in the garage, I smile every day
6/29/2012 New 2013 ordered...
8/21/2012 New 2013 picked up!!!
SnowVert is offline   Reply With Quote
Old 06-29-2013, 01:32 PM   #3
rajgopal2rajesh
Awesome man
That fixed the issue.
My link is back
Old 06-29-2013, 04:13 PM   #4
SnowVert
SnowVert's Avatar
Glad I could help!
m2w mild wild 2013 2lt mylink
