01-20-2019, 03:26 PM | #1 |
Drives: malibu maxx ss chevy ss Join Date: Aug 2016
help with head selection
I was thinking about buying some heads. My choices are SPS haymakers, TF 255's or ported LSA's. What are your guys thoughts. I will add cam and ported LSA blower with Meth on 93 octane. ARH 2" primaries, What areyour guys thoughts. Is the extra cash for haymakes or TF worth it over ported LSA heads.
01-20-2019, 07:33 PM | #2 |
Tri-County Camaro SWFL
Just a few more options...... MAST Black label, Brodix, TSP
The benefit of aftermarket heads over a ported OE would be that you could utilize a 6 bolt head and use them on the OE block for room to grow.
01-20-2019, 09:38 PM | #3 |
Drives: 13' 1LE Join Date: Apr 2012
GMPP cnc, TEA, FED...
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
01-20-2019, 09:39 PM | #4 |
my head selection is staying around $2500 give or take
01-20-2019, 10:10 PM | #5 |
Drives: 2013 Camaro SS Join Date: Apr 2017
I went with the Trickflow Gen X 255 heads with the upgraded valves. I then had them milled and given a valve job to make sure everything was right. I like them but believe I would have gotten close to the same performance from a GPI or TSP head for a lot cheaper. I do like the increased valve angle to give more clearance and GPI and TSP have that option as well i believe.
2013 SS M6, TSP Stage 3 231/246 cam kit, TSP Trunion upgrade, Cold Air Inductions CAI, VMAX PTB, TSP 1 7/8 Long tube headers and high flow cats, Corsa Xtreme ZL1 Catback exhaust, Elite E2-X Catch can, Trick Flow Gen-X 255 heads milled 0.025 and valve job, GPI rod mod and ported intake, ID850 injectors,ZL1 fuel pump, Flex sensor and E-85, Mantic 9000 and 1LE 3.91 diff 512rwhp/462rwtq
01-20-2019, 11:21 PM | #6 |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
I tun TFS GenX 255's....
Stage 2 ProCharger D1X at 14lbs peak boost (3.9" pulley) made 760rwhp on E85 by 6,800 rpm's with a TSP VVT 3.2 cam.
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
01-21-2019, 11:51 AM | #7 |
Drives: 2015 2SS 1LE Join Date: Dec 2016
Have you talked to Brett at Landspeed performance? He currently has my heads.
505/465: 416 stroker, landspeed stg 3 heads, 10.5 compression, btr stg 3 stroker cam, E85, kooks 1-7/8" headers,k&n intake,vmaxx tb,mgw,rxt,bmr 1.5" drop springs,bmr poly cradle bushings,bmr toe rods,bmr trailing arms,bmr uca,bmr diff bushings
01-21-2019, 07:50 PM | #8 |
I went with a set of haymakers. But now I need to determine combustion chamber size. I always thought bigger was better. more room for boost. How wrong am I. How can I determine the correct size for my application
01-21-2019, 08:38 PM | #9 |
Drives: 2007 Corvette C6 983 RWHP Join Date: Dec 2011
Chamber size will effect compression. Its not about the biggest heads, but the right ones for your combo.
If whoever is selling you the heads cant help you make good choices, I would buy them elsewhere.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam YSI / 3.0 pulley, ARH 1 7/8 headers, NPP Dewitts / dual spals, A&A dual pump fuel system. 3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me. ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper Circle D Triple Disc stall 1009 RWHP @ 7000, 817 RWTQ @ 6000, |
01-21-2019, 08:42 PM | #10 |
i understand that but I want to learn how to figure the correct ratio for certain applications. whats best for what. So i guess I want to the knowledge
01-21-2019, 08:43 PM | #11 | |
http://www.wallaceracing.com/Calculators.htm
01-21-2019, 08:45 PM | #12 |
what compression ratio is best for what applications
01-21-2019, 08:47 PM | #13 |
You have some reading to do. Its not that simple. Depends on fuel, boost, camshaft, type of usage and how safe you want to play the game.
In general LS engines seem to like 10- 10.5 with boost from my experience. You will get many different answers on that.
01-21-2019, 08:51 PM | #14 |
exactly. Im trying to find a some good books. any suggestions
