09-02-2021, 01:24 AM | #1 |
Drives: Camaro ss Join Date: Jul 2021
Grinding or abs sound when turning?
Hey guys I noticed this sound while turning and while turning and reversing
It’s NOT like a metal grind but more like an abs humm or the abs coming on and off and I don’t see any lights or anything when it happens Has any one experienced this before? Car only has 21k on it 2010 2ss Found the issue not really an issue but the steering wheels flexing Last edited by moezer; 09-03-2021 at 10:50 AM. |
09-02-2021, 05:49 AM | #2 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
Has the differential been serviced lately?
09-02-2021, 07:29 AM | #3 |
Drives: 2011 Camaro SS R/S Join Date: Jan 2011
It’s a known issue with this car. The noise comes for the clutches in the differential slipping and sticking, and repeat. The official GM fix, which was a TSB is to put a different fluid and additive. This however also requires the differential seals to be changed as the new fluid will leak with the original seals. I had my 2011 fixed a few years ago and it’s been good since. Mine started showing up around 13K miles. Others might know of different fluids that can be used without changing the seals.
09-02-2021, 08:27 AM | #4 | |
09-02-2021, 10:37 AM | #5 |
Drives: 2011 Camaro SS Join Date: Jul 2019
I already researched this in the spring because my car was also doing it. When my cam was installed in the spring I had the shop change the diff oil. Haven't had an issue all summer.
EPS CUSTOM GRIND CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBE HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3800 Pro Series stall...391 gears.....Ported/modded GPI intake .Forgestar drag pack with Mickey Thompson ET street drag radials AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
09-02-2021, 11:05 AM | #6 |
Sorry guys this sound is coming from the front of the car not the rear, and only when I’m turning right and reverting and have my tires turned right
09-02-2021, 02:51 PM | #7 |
Ok for sure it’s not the diff, i was coming off my drive way and as I came to a full crank to the left it did the sound and I can feel it in the brake pedal
Could it be the abs airing out or something? My brakes are good and clutch is good Sent from my iPhone using Tapatalk |
09-02-2021, 02:59 PM | #8 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
[QUOTE=moezer;11064572]
Could it be the abs airing out or something? QUOTE] No |
09-02-2021, 06:53 PM | #9 |
If I were you and had this issue going on and it is coming from the front, from my past experience from NOT checking out my front suspension on my 1979 Thunderbird when I heard something weird and felt it too, and one day turning onto a parking lot and all of a sudden she went POP, CLUNK.... And there I was, the right front sitting on the ground with a broken lower ball joint!! Take your car to a shop and put it up on a lift and check all your front suspension and brake rotors and calipers!! Move stuff around for play and look for excessive wear before something breaks and your stuck, or worse yet, have an accident!! Be safe about it and stop guessing. You'll thank me later. Good luck sir.
09-02-2021, 07:01 PM | #10 |
Drives: ABM #93 Join Date: Oct 2018
I’d check the front hub bearings real good.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
09-02-2021, 07:34 PM | #11 |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
what 1JEWLDSSRS said.
noises in the rolling bits are not good. Noises in the steering or stopping bits really should be physically checked sooner rather than later. |
09-02-2021, 10:47 PM | #12 | |
Drives: Camaro Convertible 2014 1LT Join Date: May 2019
09-02-2021, 11:32 PM | #13 | |
I’m the mechanic on all my cars my cars don’t see a shop unless I need a wheel balance or an alignment I’ve already check everything u mentioned everything is solid and doesn’t show any kinda wear the house happens when I’m moving slow back up or when turning slow doesn’t do it when I’m driving normal speed Also doesn’t shake or shimmy when I press the brakes or driving fast and no abnormal tire wear I bought the car with 15500 k km now has 21000 Sent from my iPhone using Tapatalk |
09-03-2021, 05:21 AM | #14 |
Drives: 2013 Camaro 2SS AGM Join Date: Apr 2020
Power steering pump or rack problem possibly?
