09-05-2019, 04:58 PM | #1 |
Drives: 2013 camaro SS Join Date: Aug 2019
ROOKIE at the strip!!!
Guys I have a 2013 auto SS. Tomorrow looks like it will be my first time on the strip. I have never done this before. Any tips and things not to do would be greatly appreciated. I’m nervous as hell. Do I run in stabiltrack? I really am new to this.
09-06-2019, 06:27 AM | #2 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Might depend on which transmission your car has.
You might get more or better dragstrip suggestions for where to set Stabilitrak/traction control over in the Dragstrip and Launch Techniques section. Norm
'08 GT coupe 5M (the occasional track toy)
'19 WRX 6M (the family sedan . . . seriously) |
09-06-2019, 09:01 AM | #3 |
Drives: 2010 Camaro 2SS/RS M6 Join Date: May 2009
Yeah, this is posted in the wrong section. In the Dragstrip and Launch Techniques subforum, there is a sticky at the top with a lot of good information. I'll make it easy on you. Click here: https://www.camaro5.com/forums/showthread.php?t=317537
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings Hotchkis sub-frame brace Stop Tech Z-23 brakes 4.10 gears, Eaton Truetrac, LPW diff cover Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA |
09-06-2019, 09:13 AM | #4 |
What mods do you have? Generally if your close to stock with a street tire just start with a half throttle punch and see what it does. If it hooks right away nail it and the next pass try a bit more gas off the line. If it spins let it finish and then nail it and next time a little less throttle off the line.
Cars hook better at the track then on the street. So be prepared to go. You can let a little air pressure out of your tires too but if they are street tires it won't do much. |
09-07-2019, 12:09 AM | #5 |
09-07-2019, 12:10 AM | #6 |
Sorry if I posted in the wrong section. Only ran twice
