02-10-2020, 02:04 PM | #1 |
Dyno Show Queen LOL
Drives: 16 SS & 17 ZL1 Both Yellow Join Date: Jan 2014
Royal Purple Syncromax SUCKS!
Changed the M6 trans oil last week with RP syncromax and the next morning when it was cold out I could barely get the car in 2nd.. Its been that cold before with the OEM oil and never had that type of a problem.
What are the options? go back to OEM, Amsoil, any Additives.. I read 3.65 Qts so I took out 12 ounces from the last bottle.. that left me just under and not dripping out the fill hole maybe a 1/16th or 1/8th below the fill hole. When it warmed up it was OK.. I'm talking 45 degrees my garage is always about 60 degrees.. By the time I got to work it felt ok, but when I left for home it was hard to go into 2nd I'm mean really hard.. Never had that with OEM stuff I driven a lot in cold with it!
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber Last edited by EDFHOBBIES; 02-13-2021 at 08:29 AM. |
02-10-2020, 02:28 PM | #2 |
Sorry to hear this. I went to Synchromax a year ago and its been fine. However, I have always had to watch the 1-2 shift on cold mornings. RP didn't change that.
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears 476 rwhp/440 rwtq (sold) |
02-10-2020, 03:06 PM | #3 |
Dyno Show Queen LOL
Thanks for the info. I called Tremec, he thinks its because the oil is thinker its harder to push out when cold. He said thicker is better for racing. He also recommended the GM fluid since it has some parts to there specs and Mobile 1 ATF synthetic. He also asked if it was better when it warmed up and how long it took to feel better.. he also recommend letting warm up which i dont really have time to do most of the time. I do let everything warm up before I beat on anything though.
I dont know its 70 today I may see if it's ok today.
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber |
02-10-2020, 06:57 PM | #4 |
TEXIT
Drives: 2019 ZL1 M6 Join Date: Aug 2018
Ouch. I have 4 quarts in my garage...
Been using RP oil for years with great results. You forcing thru the skip shift lol??? |
02-10-2020, 07:20 PM | #5 |
Dyno Show Queen LOL
That's the 1sr thing the tuner got rid of lol
02-11-2020, 07:20 AM | #6 |
Drives: 18 1SS 1LE HyperBlue Join Date: Aug 2018
I ran Syncromax for awhile, and ended up switching to Amsoil ATF as it was easier for me to get locally. I think the ATF is smoother, but not by leaps and bounds.
However the Syncromax felt better when it was fresh, but after 6k miles or so, it didn't seem to be as good as when it was new. The ATF thus far doesn't seem like it has faded at all (about 4k in driving)
2018 1SS 1LE / HBM - ECS Novi 1500 S/C Tuned by Carl @ CJ Tunes
02-11-2020, 08:10 AM | #7 |
Drives: 1SS Hyper Blue Metallic, MRC, NPP Join Date: Apr 2016
Sorry that it didn't cure the 1-2 shifts for you but I appreciate the feed back as I was debating between RP Syncromax and the Red Line D4 ATF, in which I will try the D4 now after hearing your 1-2 shifts are harder.
02-11-2020, 08:22 AM | #8 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
I do have the issue as well with getting my short throw into some gears, like your forcing it here and there but tends to clear up pretty quickly. I thought I was the only one, i might change as well now :(
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
02-11-2020, 09:54 AM | #9 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
Best advice I've read on the site lately regarding the 1-2 issue is after starting up, run the shifter thru the gates a few times- esp. the 1-2 shift before you begin driving. It just takes a few seconds.
Seems to really reduce my 2nd gear "hang-up"! |
02-11-2020, 10:06 AM | #10 |
I ended up just purchasing the stock fluid right now, i did a clutch swap the same time i did the trans fluid. I'm going to see if Royal Purple is at fault for my hard to do shifts, i don't track my car or drive it a lot so i don't care what i put in it as long as it works... I'll probably go amsoil next go around though.
02-11-2020, 10:42 AM | #11 |
Who Needs to KNOW?
Drives: 18 ZLE Join Date: May 2018
Whatever OE oil is it works great cold through hot. Perhaps RP is more suited for warmer climates or track only where you can let car warm up ?
ing for grip.
Are you in the NY/NJ/PA/CT region? Join us for autox fun at MetLife Stadium. HUGE lots, tons of runs. http://www.motorsportsne.com/ |
02-11-2020, 02:45 PM | #12 |
Drives: 6th gen Join Date: Aug 2013
Maybe it will shear down after some use?
‘22 2SS 1LE M6 Summit White - RF, Flexfuel, LT2 intake, 95mm tb, ATI udp, VT ramair, full 28” dragpack - 11.68@122
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold) |
02-11-2020, 04:18 PM | #13 |
Next time I'm going to try Motul 75-90w 100% Ester Synthetic. I put the 10-40w version in my motorcycle this summer (Yamaha FZ09) and it went from a good shifter to a GREAT shifter! A really noticable difference and it has stayed that way.
Has anyone tried the Motul in their car? |
02-12-2020, 08:47 AM | #14 |
I’m using rp. No complaints. Not sure if it was worth switching, I’m not positive but I think it lowered my mpg! I bet it thins out quick and will get better.
As I’ve said for a long time I usually skip second gear unless needed and I never need it while I’m warming up the car. I keep getting flamed on for this, but I don’t see issues. How often u bleed ur brakes?
