08-28-2019, 05:53 AM | #1 |
Firewall Insulation
I had to replace the left piece of firewall insulation after a mouse chewed a hole through it. Of course I ended up ruining the new piece trying to put it in....ugh. I also need to replace the center piece behind the engine. Has anyone replaced that one? That one looks tough to do, if not impossible without the engine being out.
08-28-2019, 06:22 AM | #2 |
Started#gottalovethatblue
I was going to suggest drop the engine. If you know someone with a lift it is a pretty straight forward process. If not, I don't know what to tell you as like you said it appears darn near impossible.
08-28-2019, 06:34 AM | #3 |
Drives: 2014 Camaro 2SS Join Date: Feb 2015
The insulation likely tucks under the trans tunnell a bit too. I don't think it's something you can just swap out without dropping the power train because it's a formed piece.
08-28-2019, 07:20 AM | #4 |
Drives: 2010 Camaro 2SS/RS Black & Silver Join Date: Aug 2010
I have replaced mine twice. It can be done without dropping the motor. Just carefully worked it behind the obstructions. It wont be perfect, but you wont be able to tell the difference. Be sure to use rubber gloves because that stuff is very itchy.
STAINLESS WORKS HEADERS-TUNED BY JANNETTY RACING-C.A.I. INTAKE-TAYLOR 409 WIRES-SOLO AXLE BACK EXHAUST-ELITE CATCH CAN |
08-28-2019, 07:29 AM | #5 |
It's a type of fiberglass
09-11-2019, 01:09 PM | #6 |
Drives: 2010 Camaro 2SS Join Date: Mar 2019
would you have that part number by any chance for the left side ?
thanks
GM Perf LS3 495 Horsepower, RPM transmissions lvl 6 tr 6060 ,Mcleod twin disc clutch, Eaton true trac diff, Driveshaft shop prop shaft and axles,, QA1, UMI,Whiteline and BMR suspension ,pedders coil overs,FAST LSXR manifold 102 MM BBK throttle Body, 102 MM CAI made from an Air raid builders kit,TSP long tube 3 inch headers
06-01-2020, 06:23 PM | #7 |
Left (passenger) side insulation part # 92195879
06-01-2020, 06:25 PM | #8 |
Yeah you were right. I was able to do mine without pulling the motor. It definitely can be done, just takes a little patience. I found the left side actually harder to do.
06-01-2020, 06:30 PM | #9 |
Valkyrie14
Drives: Chevrolet Camaro SS Join Date: Mar 2020
How necessary is it? I removed the center piece to install my LSA blower and haven’t really thought about replacing it or even if it would fit if I wanted to.
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
06-01-2020, 06:40 PM | #10 |
IDK, but I had a hard enough time getting my hands back there for my grounds, oil pressure sensor, etc. I tore the heck of out mine during my engine swap and now it looks like shredded ass. The center piece is gone and the driver's side is shredded pretty bad.
I would imagine it helps to cut down on noise and heat, but to what extent I don't know. Valkyrie, you get that monster running yet? I would love to do an LSA swap on mine.
06-01-2020, 07:19 PM | #11 |
I am not "Fast & Furious"
Drives: 2010 Camaro LSX454 1LE Join Date: Nov 2008
I recently replaced my insulation pieces when I had my intake manifold out. That made the center piece much easier. The driver side is easy. However the passenger side is difficult due to the brake lines that run up against the firewall.
The day I take a bend too fast
Judgement that could be my last I'll be wiped right off the slate Don't wait up 'cause I'll be late, I'll be late |
06-01-2020, 10:24 PM | #12 |
Do you remember around what they cost per section?
06-01-2020, 11:59 PM | #13 | |
Valkyrie14
06-02-2020, 06:11 AM | #14 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
I've run mine without the left side or rear for years with no ill effects. I think it's as much for sound deadening as it is insulating
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
