06-20-2016, 10:57 PM | #1 |
Drives: 2015 AGM 1LT Join Date: Jul 2015
Overkill TB and VTC
Hey guys. I've been out of the loop for a while and it looks like I missed a ton. Been reading the Overkill thread to catch up on everything. I noticed no one seems to have mentioned anything about running a Overkill TB with the VTC and if so how well they work together.
In my case I had to take my VTC off after i put the Vmax on as it threw so many codes the car wasn't driveable. I was wondering if the this new throttle body could give those of us who have issues with the Vmax a way to run both the controller and a better throttle body. |
06-21-2016, 10:34 PM | #2 |
Drives: 2013 Camaro 2LS Join Date: Oct 2015
I ran the 80mm throttle body with the VTC for two weeks (on stock tune) while waiting for other parts and had no problems. super fun to drive!
2013 2LS - K&N CAI, Overkill Ported 80mm Throttle Body, Overkill E85 Kit and Overkill Tune, Jacfab Ported Intake Manifold and Spacer, Stealth 3.0 TC, ARH Catted Downpipes, Magnaflow Resonated X-Pipe, Resonator Delete, Jones Full Boar Racing Mufflers, BMR 1.2" Lowering Springs, Elite Engineering Catch Can and Clean Side Seperator
06-21-2016, 11:12 PM | #3 |
Drives: 2015 vicious animal with 217 cu i Join Date: Mar 2016
I noticed that everyone tries to ditch the VTC before even testing it with other mods.
"Well I'm adding a ________ , time to sell my Vitesse, even though ____ has nothing to do with throttle response...hur dur" |
06-22-2016, 05:27 AM | #4 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
I use the VTC all the time. Usually setting 5 or 6.
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
06-22-2016, 05:38 AM | #5 |
I have the 80mm tb with ipf tune and no codes to date. I run the Vtc on 2. I don't plan on removing it unless I get overkill tune and I find it has no affect either way, but for now it sure helps. I also have intake port matched and extender. I probably need to get the overkill tune but it seems to run great as is.
Now if you want to talk issues, how about the tpms system. |
06-22-2016, 07:32 AM | #6 |
Drives: 2015 Black 2LT RS M6 Join Date: Aug 2015
This. I leave mine on 5 unless I feel the need to just have a little fun. Since day I have never had a single problem with it and it works perfectly with all my mods
Overkill tune/E85/80mm•CAI cold air intake w/my custom maf tube•Apex air scoop•JacFab ported intake/Extendolater•Vitesse•EE EX2 catch can•Innovate wideband•ARH HFC's•NPP exhaust•11386 xpipe•Brembos/cross drilled/slotted rotors•SS M/C•Pfadt 1.25 springs•1LE struts/sways/strut tower brace•BMR diff bush, trail arms/bush, adj toe links•My custom Tunnel brace•Hurst short throw shifter•JDP stage 1 clutch res•1LE steering wheel, shift boot•ZL1 rear diffuser/splash guards•GM splitter•Z/28 grille/flowtie/spoiler/wheels•GM performance pedals•"Chevrolet" door sills•10" Kicker sub•BigWorm overlays
06-22-2016, 11:19 PM | #7 | |
I can say that I have done some testing on mine. I had my VTC on for about 6 months with no issues but about 1 month after install of the VMAX I started getting throttle codes. I took the VTC off and the car would run fine, put it back and back to codes being thrown. I gave up when it got so bad that the car would go into limp mode just by backing up. It seems like there hasn't been any issues using the 80mm one so I might grab it to see if I can run it. I know it need s a different intake tube but does it require getting a tune since its larger or is it just plug and play still? |
06-23-2016, 03:07 AM | #8 | |
Drives: 2013 1LT RS Camaro Join Date: Apr 2016
06-23-2016, 09:51 AM | #9 |
Drives: Black 2015 Camaro 2LS Join Date: Aug 2015
Does the VTC throw a check engine?
Magnaflow axle back with custom j-pipes, K&N intake, VTC, 20inch matte black SS rims,245/45ZR20W tires, z28 spoiler, black bow ties and tint.
06-23-2016, 11:13 AM | #10 |
08-16-2016, 08:50 PM | #11 |
Drives: 2013 v6 auto 1LT Join Date: Oct 2012
WHAT IS VTC ?
08-22-2016, 07:58 AM | #12 |
Drives: 2015 Dodge Challenger R/T Scat Pack Join Date: May 2016
It's a throttle controller from Vitesse Motorsports and its for decreasing the lag between when you press the pedal and when the car actually takes off. If I'm wrong someone correct me.
“It is not that I'm so smart. But I stay with the questions much longer.”
― Albert Einstein |
08-23-2016, 04:48 AM | #13 |
Drives: Ly7 Join Date: Dec 2011
I`m selling my Stealth Controller if interested.
http://www.camaro5.com/forums/showthread.php?t=463332 |
