#Camaro6
Old 02-16-2024, 08:25 AM   #1
crisspy24
crisspy24's Avatar
Drives: '24 CE Camaro 2SS
Exhaust Valve
What does it mean to fully open the valve by pulling the fuse? And does that cause any long term damage to the vehicle?
crisspy24 is offline   Reply With Quote
Old 02-16-2024, 09:47 AM   #2
Nothing like an SS
Faster!!!
Nothing like an SS's Avatar
Drives: 2020 Camaro 1SS 1LE
It means the valve is fully wide open at all times, no it won't, it is only bypassing the muffler, the last stage of the system. Neighbors on the other hand, those could be permanently damaged! LOL
Nothing like an SS is offline   Reply With Quote
Old 02-16-2024, 11:40 AM   #3
crisspy24
crisspy24's Avatar
Does pulling the F51 Fuse cause a check engine light at all?
Old 02-16-2024, 11:42 AM   #4
Justcruising
Justcruising's Avatar
Drives: 2019 Chevrolet Camaro 2SS
None at all
Justcruising is offline   Reply With Quote
Old 02-16-2024, 10:19 PM   #5
GroundhogSS
GroundhogSS's Avatar
Drives: '17 2SS convertible'20 Yukon Denali
I've had it out for probably 70K miles and no problems yet, and no CELs.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers
Delivered: 08/15/2016
#TeamBeckyD
GroundhogSS is offline   Reply With Quote
Old 02-16-2024, 11:42 PM   #6
RIPws6
RIPws6's Avatar
Drives: 2019 2SS Riverside Blue
It’s a great alternative to buying an upgraded exhaust system. I drove mine without the fuse for a year. Big improvement but once you get to cruising speed, AFM takes over and your car will go from nice growl to silent. So having open valves is good, getting rid of AFM is even better. I don’t want to assume you know what AFM is so in short, Active Fuel Management is what turns off 4 cylinders and puts you in V4 mode. The factory puts this in to avoid charging a gas guzzler tax on the sticker. The latest version of the GTO did not have AFM so as a result, anywhere from $1000-$2000 was added to the sticker.
So, when you pull the fuse, be aware that after you hit cruising speed, it’s going to be quiet, no matter what you do. I eventually got MbRP exhaust, which has no valves at all, and I still have the same issue for the above stated reasons.
To save wear and tear on your lifters, you can either tune out the AFM or purchase a product called the rangefinder for about 300 bucks. This little gadget plugs into your computer port and will harmlessly disable AFM for as long as it is plugged in. Many people here are using it with no issues.
RIPws6 is offline   Reply With Quote
Old 02-16-2024, 11:59 PM   #7
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
It does cause a code, you won't see it, but a dealer can when they scan your car.
Everything happens for a reason, except when it doesn't, but even then, you can, in hindsight, fabricate a reason that satisfies your belief system.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
