09-12-2018, 08:36 AM | #1 |
Drives: 2011 Camaro Join Date: May 2015
Advice on trans cooler mounting location-with pic
Hey guys. I'm trying to decide on where and how to mount a trans cooler. 1st off, I'm doing a stand alone cooler without routing through radiator; have my reasons. 2nd on advice of cooler manufacturer and a trusted C5 member I'm need to go with at least a 34 stacked plate cooler.
The diagram below illustrates 1. (Red) Top center back close to condenser. 2. (Blue) lower right and mounted to crash bar. And 3. (Green) 2 smaller 16 rows ran in series (if possible). Some concerns that have ran through my mind as I over think this is; Will the red cooler location block to much air and/or introduce hot cooler air into radiator defeating the effort to lessen the heat stress on it? Will the blue location have too much surface area blocked by crash bar/fascia to be effective even though there is flow from lower valance moving in and up the surface? Problems with running two coolers in series more or less effective than 1 big one? Just looking for any suggestions, thoughts or concerns before I tear into this. TIA. |
09-12-2018, 09:33 AM | #2 |
'It's an experiment'
The lower area has the highest air pressure so it will get a lot of air. I've found that if I put in the biggest cooler (upper in my case), heat is not a problem. IF you have no other coolers to worry about, I'd get the biggest cooler that will fit in the lower area (green).
Otherwise, what I did has worked perfectly: Adding air dams also helps direct the air where you want it... -Don
747 RWHP 794 RWTQ
09-12-2018, 03:03 PM | #3 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
I installed Tru-Cool Max LPD 30,000 Transmission Oil Cooler 4921-1 49211
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 in the lower area since it just the right size for the lower slot. |
09-12-2018, 10:07 PM | #4 |
here is mine
09-12-2018, 10:32 PM | #5 |
Interesting....Did you completely remove the "plastic" air deflecter or modify it. Wondering if a "frame for the cooler could be made and fitted inside the existing plastic deflector. I do have an aftermarket lower splitter/valance that would cause some additional problems. Thanks for helping me think outside the box.
09-12-2018, 11:02 PM | #6 |
Angewendet Ingenieur
Drives: 14 Camaro ZL1 Join Date: Apr 2015
I think your right on point. I used a tru-cool 40k with a thermostat “stand alone” works great and no overheating issues. I run a intercooler and oil cooler as well in the same area.
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah. |
09-13-2018, 02:44 AM | #7 |
No deflector
09-13-2018, 05:16 AM | #8 |
Works perfect at all speeds. deflector is just blocking airflow.
09-13-2018, 11:13 AM | #9 |
Team 913
Drives: '14 ZL1, '15 Jeep GC, 22 Ram 2500 Join Date: Apr 2015
09-25-2018, 10:16 PM | #10 |
Thanks for all the help and suggestions. Here is what I ended up doing...
https://www.camaro5.com/forums/showthread.php?t=539448 |
09-29-2018, 03:35 PM | #11 |
I know you already finished yours, but for anyone else interested. This is how I mounted mine. Cooler is an eBay special 7x17x2" with -6 an lines. Never seen over 190° cruising hot SC days around town.
Ben |
Thread Tools | |
