11-15-2013, 04:24 PM | #1 |
Mother of PWA Babies
Drives: 2011 RJT 2LT/RS Join Date: Apr 2011
Odd sound when headlights are on
Does anyone know what could cause this noise in the video? Only happens when my headlights are on.
http://youtu.be/wVaUe1SkjvA
11-15-2013, 04:39 PM | #2 | |
Better video. Pretty sure it is the drl's
Sent from my iPhone
11-15-2013, 05:31 PM | #3 |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
Wow. If that's the relay, get that sh*t fixed ASAP.
11-15-2013, 05:43 PM | #4 |
I'll be back...
Drives: Subaru, HD Road Glide Special Join Date: Apr 2012
That's a bad relay, or weak ground for the relay. Relays are super-cheap; try a new one first. If there is an identical relay already elsewhere in the system, swap them and see if the noise follows the suspected "bad" relay.
Bye bye, Bumblebee!
11-15-2013, 05:44 PM | #5 |
Should I take it to the dealership or can I fix myself
11-16-2013, 10:14 AM | #6 |
Update. It is not the relay
11-16-2013, 10:58 AM | #7 |
Banned
Drives: 2011 Chevy Camaro Join Date: Sep 2010
It's the ballast for your HIDs i think. What kind of ballasts are you running? Cheap Chinese ones will make that buzzing noise.
11-16-2013, 11:01 AM | #8 |
It doesn't make the noise when the relay is out. It something with my DRLs, we disconnected them and it stopped. Something is causing the relay to "freak out"
11-16-2013, 11:21 AM | #9 |
Banned
Not enough trigger amperage would be your best bet. That doesn't look like a factory piece. And there is aftermarket wiring right there to so the dealership will help you but it won't be under warranty I don't think.
