Old 10-03-2018, 11:08 PM   #1
mactube
Drives: 2015 Camaro Convertible
Rattling noise + Engin Check Light on!
Does somebody know what kind of part this is ( picture ) ?
There is a pretty loud rattling noise coming from that direction ( that I can here from inside the car ) and when I touch this part ( which I can read "Bosch" on) and kind of apply some pressure on it by pushing it down , the noise gets louder and I can tell it is coming from that part. The check engine light came on a day before the rattling noise started. And I'm still waiting on my check engine light code reader the I ordered, but I'm pretty sure the noise and check engine light have something to do with each other ..
2015 Camaro V6 Convertible
Link to picture: https://www.dropbox.com/s/tllgqovgl0...amaro.jpg?dl=0
mactube is offline   Reply With Quote
Old 10-04-2018, 09:12 AM   #2
JerTM
JerTM's Avatar
Drives: 2011 2SS/RS M6
What is the dtc? That part is the EVAP purge solenoid, they can make a lot of racket.
JerTM is offline   Reply With Quote
Old 10-04-2018, 04:59 PM   #3
mactube
@JerTM not to sure where I can find the etc!? But yes I found the part its the Evaporator Emission Canister Purge Solenoid Valve. Thank you ! The part no. is : GM 12610560
I have the problem with my 2015 Camaro convertible but I remember hearing this noise intermittently from my 2014 .. So I think this may be not normal but probably not a strong problem to the Camaro. But the Check engine light is on, So I'm assuming the part is broken. I'm also feeling a very high gas usage so that might have something todo with it as well.
