Old 06-02-2018, 06:45 PM   #1
Motorboy8769
Drives: 2015 2ss
Jerico 4 speed going in the car
I got a deal on a Jerico. So I bought it and started the process 5 days ago and everything is done except for some clean up and minor stuff. Currently waiting on linkage and my new clutch disc for final assembly. This task turned out to be more than I expected for sure but i think this will be well worth it when it's done.
Motorboy8769 is offline   Reply With Quote
Old 06-02-2018, 06:47 PM   #2
Motorboy8769
Drives: 2015 2ss
I don't have any pics after the cutting and massaging of the tunnel to clear the linkage but I will get some tomorrow. Should be racing next Saturday! If everything shows up on time
Old 06-04-2018, 12:19 PM   #3
BandRcAMARO
Drives: 2010 Camaro 2SS/RS
Just wondering why a 4 speed?
2010 Camaro 2SS/RS
BandRcAMARO is offline   Reply With Quote
Old 06-04-2018, 04:28 PM   #4
Motorboy8769
Drives: 2015 2ss
I only used 4th anyway eventually I may go to a 5 speed liberty. Also the price was right on the Jerico. Plus I don't ever street drive the car anymore really
Old 06-04-2018, 07:48 PM   #5
Blakester
Drives: 2010 1ss
Awesome! Care to share your ratios?
Blakester is offline   Reply With Quote
Old 06-04-2018, 08:17 PM   #6
Motorboy8769
Drives: 2015 2ss
The Jerico I a 3.08 1st gear I don't have the other ratios though and 4th is 1:1. Rear gear is 4.57 pro gear
Old 06-05-2018, 01:35 AM   #7
Bo White
Bo White's Avatar
I hardly ever used my OD gears either. Thats why I went th400
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 06-07-2018, 12:12 AM   #8
Motorboy8769
Drives: 2015 2ss
Old 06-07-2018, 08:56 AM   #9
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Just curious about what has to be done with the yaw-sensor that controls the HSA feature that was under the console lid (can it be left out,put it back in or replace it with an auto-tranny one)? ...not that you’re gonna be launching uphill LOL
camguynj is offline   Reply With Quote
Old 06-07-2018, 10:01 AM   #10
xc_SS/RS
Drives: 2010 Camaro SS/RS
you can replace it with one from an auto i believe
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 06-07-2018, 01:08 PM   #11
camguynj
camguynj's Avatar
Yes I know. I replaced mine with the auto version to get rid of that HSA crap. I'm curious if you can eliminate the yaw-sensor altogether or is it also needed for traction control ?
Old 06-07-2018, 09:07 PM   #12
Motorboy8769
Drives: 2015 2ss
Is that the computer box with 2 big yellow plugs on it? I pulled fuse 40 and 43 and HSA didn't work after that anyway so I just took it out
Old 06-07-2018, 09:09 PM   #13
Motorboy8769
Drives: 2015 2ss
Is this what you are talking about? It has airbags on it which I also pulled those fuses too so I had no issue. But you if I didn't remove it I was going to relocate it between the tunnel and the carpet because it was ugly.
Old 06-08-2018, 06:19 AM   #14
camguynj
camguynj's Avatar
Originally Posted by Motorboy8769 View Post
Attachment 939905
It has that shape but that’s not it. See this link for a pic of it https://www.sourceoneautoparts.com/g...-13581120.html
See this link for the automatic trans version to eliminate HSA https://www.camaro5.com/forums/showt...&highlight=HSA
