07-23-2020, 10:18 AM | #1 |
Drives: 2013 camaro ss 1le supercharged Join Date: Apr 2016
FUEL PRESSURE DROPPING
MY 13 SS SUPERCHARGED CAMARO IS DROPPING FUEL PRESSURE
I HAVE A DSX FUEL SYSTEM WITH E85 FLEX FUEL SENSOR AND TOOK TO DYNO AND IT CONSTANTLY DROPS FUEL PRESSURE CAUSING A MIS. HAS ANYONE HEARD OF THIS AND WHAT COULD BE THE ISSUE? |
07-23-2020, 10:36 AM | #2 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
how much it is dropping? The FPCM must be programmed to not allow the pressure to drop for one. Is it continually dropping or is it dropping by 10psi and staying there? How much power? how much boost? What Injectors?
07-23-2020, 10:48 AM | #3 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Your tuner should be able to point you in a direction to start, If they can't I wouldn't trust them to tune.
07-23-2020, 02:29 PM | #4 |
SLP SUPERCHARGER 8-10 LB OF BOOST DSX FUEL KIT TEXAS SPEED LONG BLOCK, KOOKS HEADERS SOLO PERFORMANCE EXHAUST 1260CC INJECTORS
AT 5500 RPMS FULL THROTTLE FULL PRESSURE DROPPED DOWN TO 39PSI |
07-23-2020, 02:54 PM | #5 |
For one I'd make sure the FPCM is programmed correctly I think it's 1 credit with hptuners. Other than that verify the aux pump is turning on, it's low enough in the tank to not be sucking air and the hobbs switch or whatever you are using as signal to turn on the aux pump is working. Are you using the stock SS pump? This should be able to be figured out by your tuner, if not you need a new tuner.
07-24-2020, 07:41 AM | #6 |
THE DSX FUEL SYSTEM HAS A BUTTON YOU HIT TO SEE IF ITS TURNING ON WE HAD HP TUNERS CHECK FUEL PRESSURE WHEN WE HIT THE BUTTON SO THAT SYSTEM IS WORKING, AND IT IT WHEN WE HIT THE BUTTON FUEL PRESSURE JUMPED TO 80PSI.
07-24-2020, 07:52 AM | #7 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
So you verified the aux pump works. Sounds like it’s not getting the signal to start. Is it on a Hobbs? I would check power/ground to the switch and the boost signal (leaks).
07-27-2020, 10:49 AM | #8 |
Drives: Camaro V6 2011 and 2014 V6 Join Date: May 2017
I have fuel pressure issue in my Camaro 2011 V6. Has a lot of misfires, white smoke in exhaust, "reduced engine power" messaje in dash, codes: P0087 low fuel pressure, P0089 Fuel regulator, P0300 multiple misfires.
Changed the High fuel pump but the problem still there |
07-27-2020, 12:28 PM | #9 | |
07-27-2020, 01:25 PM | #10 | |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
