Old 11-11-2018, 10:50 AM   #1
borqueztony
Drives: 2012 Camaro 2SS 6 Speed Manual
TR6060 shifting fix!
I have a 2012 Camaro SS with a Texas Speed stage 2 cam, FAST intake, Vararam induction system, long tubes, ZL1 fuel pump with booster, Zex blackout nitrous, all tuned Jannetty Motorsports. It makes 496hp at the wheels all motor and 746hp on nitrous. I’m running the stock TR6060, but upgraded with rear end with an Eaton trutrak, 1320 750hp axles, LPW reinforced cover, 3.91 gears, and all poly mounts. As most of you have experienced the TR6060 becomes sloppy when excessive power is introduced. I tried to buy time with expensive transmission fluid but the shifting and driveline slop was still there. I was about to break down and send my trans to get rebuild by Tick Performance for 3 grand when a friend of my recommended Arch Oil. I researched it and found it was basically a boron oil additive that could be put in a motor or manual transmission. With nothing to lose I drained and filled the tranmission with Valvoline synthetic transmission fluid and added 6 ounces of Arch Oil to it. I drove the car and noticed a little difference. The next day though all the shifting issues were gone! The slop in the driveline feels drastically reduced. It was so much of a difference I regretted not doing a before and after video. It’s been a few weeks now of great shifting and I’m ready to share this with everyone. If you are having the same issues I recommend you give this a try!
borqueztony is offline   Reply With Quote
Old 11-11-2018, 11:58 AM   #2
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 NPP BRM
What was the expensive brand you tried?
camguynj is offline   Reply With Quote
Old 11-12-2018, 05:06 PM   #3
borqueztony
Redline
Old 11-12-2018, 05:50 PM   #4
xc_SS/RS
Drives: 2010 Camaro SS/RS
So how does oil reduce driveline slop?
2010 2SS/RS
Z/28 intake, ported TB, vr wedge, rod-mod intake, speed engineering LT's, 3" exhaust, ATI -10% pulley, MGW shifter, 160* t-stat, HP Tuners, some suspension work, stickers and a little weight loss. 12.72 @112.36 - improvements coming
xc_SS/RS is offline   Reply With Quote
Old 11-12-2018, 05:57 PM   #5
Zl1dad
Zl1dad's Avatar
Drives: 2013 zl1
What he said^^^^
Sent from my HTC 10 using Tapatalk
Zl1dad is offline   Reply With Quote
Old 11-12-2018, 06:40 PM   #6
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2013 Camaro TT LS3
Redline D4 ATF got my 1-2 shifts much smoother. With the OEM fluid, I'd get the 1-2 grind during shift and an occasional missed shift while racing. The Redline made shifts smoother. As for driveline slop - it can't help there.
825WHP / 835WTQ at 13.7psi on E85 10.8sec@129mph DA 7,724ft at 14psi boost on SBE
AGP 56/61 TT | BTR Turbo Stage III cam | AEM TruBoost | n2mb WOT | ID-1000s | NGK BR7EF | DSX Flex Fuel Sensor | LPE
Twin Fuel | KB BAP | Monster LT1-S Triple | 3.25 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
LSX427 | AGP 65/65 TT | BTR TT Custom Grind cam | ID-1700x | AGP Triple Fuel | (build almost complete) | target >1,200rwhp
dreksnot is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
