Old 11-12-2018, 07:56 PM   #1
ZOOK
ZOOK's Avatar
Drives: 2010 2ss 6 speed
LT1-S TWIN DISC
I just received my new Monster LT1-S TWIN DISC for my winter project.
Any link on the install / tips
Thanks in advance
ZOOK
ZOOK is offline   Reply With Quote
Old 11-16-2018, 11:38 AM   #2
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
To got to the upper bellhousing bolts, try this if you have enough 3/8" extensions:
Before you mess around with the transmission jack, just put a floor jack under the tail of the tranny just in front of the crossmember. Take the weight off the crossmember and remove it. Now lower your floor jack so that you can see the upper bolts:
Like I said, you will need a lot of extensions. I have a 24" ext, and a few shorter ones:
It helps if you have a "wobbly" extension or two:
And you just poke it up there and remove the upper bolts:
After you get the upper bolts out, leave the four bottom bellhousing bolts in. Jack the trans back up and reinstall the crossmember temporarily with a few bolts. Now you can get rid of the floor jack and continue removing everything else. I try to get as much stuff as I can removed before I position the tranny jack because it is hard to work around.
Good luck.
zlathim is offline   Reply With Quote
Old 11-16-2018, 01:34 PM   #3
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
Good advice ^^^, when putting the trans back you may need to jack the front of the engine to make it tilt back to reach bolt holes. Some loosen motor mounts and tilt engine back to make it easier to line the trans back up
Stock LS3 motor with BTR Stage 1 Turbo Cam, Monster LT1-S Clutch, Huronspeed turbo kit, Precision pt8847, Squash E85 fuel system, Aem Meth injection, Dsmlights Tuned
905whp 19psi - 10.2@142 16psi
https://instagram.com/turbo_ls3/
fif_gen_powa is online now   Reply With Quote
Old 11-16-2018, 01:58 PM   #4
zlathim
zlathim's Avatar
I din't have to do that, but it is a good trick to know. Thanks.
CAI Cold Air Intake; Comp Cams LSR Series; EE E2 catch can;
SP 1 7/8" LT Headers w/ hfc; Flowmaster AT 3" cat-back; AEM Wideband; tuned by Throttle Works 467whp 419 wtq
McCleod RST; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Old 11-16-2018, 02:57 PM   #5
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Want even more room?
The front cradle has 6 bolts holding it in. The front two loosen a little bit. The middle two loosen about halfway. The rear two, take them completely out.
Old 11-18-2018, 06:36 AM   #6
ZOOK
ZOOK's Avatar
Thanks for all the tips .I'm sure they will come in handy before i'm done.
Has anyone used this clutch ?
http://monsterclutches.com/gen-5-cam...et-gen5-clutch
Old 12-03-2018, 05:09 PM   #7
SSBUSDRVR
SSBUSDRVR's Avatar
Drives: '11 2SS/RS IBM/BLK M6
Have the Triple here. Great Clutch imho and their power ratings are very conservative. Should enjoy the Street manners. Why went with the S instead of the SC. ( well Builder suggested that lol) Best Wishes.
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416
ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly
SSBUSDRVR is offline   Reply With Quote
Old 01-02-2019, 02:00 PM   #8
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
this is the way i've seen it done various times. its supposed to make the reinstall a breeze as well because of the angle the engine is in at that stage
sixty9fordkiller is online now   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
