02-25-2018, 03:19 PM | #1 |
Drives: 02 Camaro B4C Join Date: Nov 2016
Wilwood EXP600 Plus
Anyone have any experience with Wilwood EXP 600 Plus?
Here is their description Dry Boiling Point Degrees Farenheit: 626 °F Wet Boiling Point Degrees Farenheit: 417 °F "Wilwood EXP Super Hi-Temp 600 Plus Racing Brake Fluid has been specially formulated for racing applications where brake systems consistently operate at very high temperatures. In addition to guarding against vapor lock, EXP Super Hi-Temp 600 Plus Racing Brake Fluid maintains its viscosity and lubricity under extreme temperatures for maintaining brake system reliability and performance. EXP Super Hi-Temp 600 Plus Racing Brake Fluid conforms to, and exceeds U.S. specification FMVSS No. 116 DOT 4. Typical dry boiling point: 594° F (312° C). Typical wet boiling point: 399° F (204 °C). It is true that racing fluids need to have high boiling points. It is also true that fluids need to have low moisture affinity to slow the natural absorption rate of water vapor. But the true test of any fluid is how well it resists aeration and compressibility after it has been heated and pressure cycled a few hundred times. The real test is at the track. EXP has been proven to maintain firm pedal feel and quick response, long after others have failed." Thanks
A man's garage is his castle
1969 Camaro SS 1970 Camaro SS 2002 Camaro B4C 2014 Camaro SS Dedicated Track Car 2015 Camaro 1SS 1LE 2008 HHR SS 1996 Silverado Crew Cab Long Bed Dual Rear Wheel |
02-28-2018, 12:31 PM | #2 |
Drives: 11 SW SYNERGY SERIES/14 1SS 1LE Join Date: May 2012
I've run that fluid for the last 3 years, autocross and road course work. Change it spring and late summer. So far so good,I've not had any problems with boiling the fluid. Only time I did was at NCM in June, 98* out, track temp 130*. Car ahead of me caught fire and we had to stop on an uphill section with no place to go. Boiled the fluid, warped the rotors and all. Such is life but no much you can do in the middle of a session on track.
2011 Summit White Synergy Series Edition, the hot innocent woman named Ava that we show off around town, dressed in white complete with angel's wings. Sold, but never forgotten.
2014 1SS 1LE. Bama, sporting Red Rock Metallic demon's horns, when we are ready to get naughty and open a can of whoopass! Airaid, Spectre, Xpel,Bowler shifter Peddars, UMI, Ult Perf. Diode Dynamics, JRE Tune, XS Power battery, Hooker Headers Blackheart exhaust,Powerbrake InstaGram & Twitter: @jlouie62 FB: hangtimeracing |
03-13-2018, 06:36 PM | #3 |
Drives: 2018 ZL1 1LE Join Date: Feb 2009
The Wilwood EXP is great stuff.
I've used it in four different track cars, over 125 track events, and never had a single problem with it. Ever.
2018 ZL1 1LE "RAZECAR" 2016 2SS Convertible "NOTOPSS" (Sold) 2015 Z/28 #306 "ITZFAST" 2010 2SS Coupe "FASSTER" (Sold) 2002 SS/RS "02FASST" (Sold) 2007 Factory Five Racing GTM "REDBLUR" (Sold) "There are two kinds of cars. Red....and everything else!" |
03-13-2018, 07:05 PM | #4 |
Drives: 2013 Camaro 1SS Join Date: Oct 2017
Agree - Wilwood EXP 600+ is my favorite brake fluid. Worked for me for both track and street
