Old 03-12-2013, 10:53 AM   #1
do1997
Drives: 2012 zl1, black
727 hp & 636 torque
12' ZL1 tuned at LMR
do1997 is offline   Reply With Quote
Old 03-12-2013, 11:09 AM   #2
do1997
Here is the dyno video
http://youtu.be/RtrcphpWt5I
Old 03-12-2013, 11:15 AM   #3
Lethal Z
American Gearhead!!
Lethal Z's Avatar
Drives: ZL1 1LE/GT350/Ford RS/Gen 2 Raptor
You cant just post a dyno chart and not give some details man!!!
Is the 509 stock baseline without any mods?? And what all did you do to it to get to that massive 727 number??
Lethal Z is offline   Reply With Quote
Old 03-12-2013, 11:16 AM   #4
davidcroft
Sellin Chevy's since '06
davidcroft's Avatar
Drives: 18ZL1 02Z-28
Tq is a bit low.
'19 Z06-7Speed and lowered on stock bolts
'02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub40K orig miles. https://youtu.be/h6faSdcvNew
TRADED!'17 ATS-V Coupe w/ Carbon Black pkg https://youtu.be/GH_t-R-TJV0
SOLD! '18 ZL1 Mosiac Blk
SOLD!'16 SS Sedan-Forgestars/ARH/rotofab
TRADED!2014 SS Sedan
SOLD! 2013 Blue Ray1SS/1LE 1of20.
TRADED! 2012 White 1SS/RS
davidcroft is offline   Reply With Quote
Old 03-12-2013, 11:16 AM   #5
Apex Paul
Apex Paul's Avatar
Drives: Wagon Queen Family Truckster
Details!
Apex Paul is offline   Reply With Quote
Old 03-12-2013, 11:26 AM   #6
do1997
LMR's Reaper package
LMR Cold Air Induction System
Solid Isolator
2.55" upper pulley
Upper pulley hardware kit
Dowel Pin
Bypass positioning tool
LMR Custom Grind Cam and Chromoly Pushrods
GM L92 Casting, 5 Axis CNC Machined, Fully Assembled Cylinder Heads
LMR Custom Heat Exchanger
160* Thermostat
10% Overdrive harmonic balancer
American Racing 1 7/8" Headers with High flow cats and connection pipes
80lb/hr fuel injectors
Kenne Bell Boost-A-Pump
NGK Iridium Spark Plugs
8.5mm ignition wires
All necessary fluids and gaskets
Professionally installed and Dyno Tuned
I also ported the supercharger and installed a Nick Williams 102MM TB
Note that the boost a pump didnt get installed yet. It will be installed this week and
should bump it another 10-15 Rwhp.
Old 03-12-2013, 11:37 AM   #7
Dega Man
Drives: ZL1
Your car made good rwhp, looking at your baseline this must be a manual tranny? It looks like you had a good spike for your 727rwhp number but 700 to 705rwhp seem very real which is impressive. Looks like your lower torque number is in part from the big 102mm tb, which the lower torque could help lessen your wheel spin off the line. Congrats on your project.
Dega Man is offline   Reply With Quote
Old 03-12-2013, 11:39 AM   #8
Dznts
Anabolic Connoisseur
Dznts's Avatar
awesome
Old 03-12-2013, 11:49 AM   #9
do1997
Thanks, And yes, it is a 6-speed.
Old 03-12-2013, 11:54 AM   #10
Congrats, awesome numbers and mods
Old 03-12-2013, 12:26 PM   #11
sonic656
Drives: 2012 Toyota FJ Cruiser
Agree 100% on the spike but awesome numbers non the less. Very cool
sonic656 is offline   Reply With Quote
Old 03-12-2013, 02:32 PM   #12
Dega Man
Drives: ZL1
Are you going back to the dyno after you install the Boost A Pump? I would like to know if you really gain anymore HP from it. My car just required less fuel during mapping and lowered the injector duty cylcle.
Old 03-12-2013, 03:37 PM   #13
do1997
Yes, They are supposed to rerun the dyno with the boost a pump installed. I should be getting it installed tomorrow. I will post update by end of week.
Old 03-12-2013, 03:47 PM   #14
Mattzl1
Mattzl1's Avatar
Drives: 2013 ZL1
Great numbers! You got those numbers with the 2.5 upper and only an 8.6 lower?
2013 ZL1 AGM, ECF, A6, sunroof, black rims
mods complete! 664 RWHP, 645 RWTQ
Ported snout, 2.5 upper, Innovators west balancer with 9.1 lower, New era intake, American Racing long tube headers with hollow cats and X pipe, KDI heat exchanger, ID850's, TS29 cam !
Mattzl1 is offline   Reply With Quote
