05-06-2018, 03:04 PM | #1 |
Drives: 2010 2SS/RS Join Date: Feb 2017
LTFT at Idle. WTF?
Hello
2010 L99, SLP S/C. 3.2", ZL1 pump, Jannetty FPCM, ID 1050X and JBA cat-delete mid pipes. After injector, pulley size drop, ZL1 pump, FPCM and JBA cat delete install. LTFT at idle logs at Bank 1 0.92 and Bank 2 is 1.04 on SCT Livelink. Quick rundown: - O2 sensors are OEM and new. - No exhaust leaks detectable. - Ran two smoke tests and no vacuum leak found - Trims are different by 10-12% at idle with Bank 2 being leaner (1.02) - When driving and at normal throttle positions, the difference closes up to 2-4% with bank 2 usually showing richer. - Tune done by Ted. The LTFT prior to the install of the parts listed above (just the standard SLP kit) was right on. - Ted caught the issue on one of my logs and suggested an exhaust leak or vacuum leak. Which I expected to find. - Have not been able to locate a leak with carb cleaner sprayed around the entire engine and two smoke tests. - Re-gasketed and torqued mid pipes to exhaust manifolds. How much air is getting by to cause a 10-12% difference between banks? I am going crazy. Anyone else dealt with this? Or, have advice on how to proceed? Thank you |
05-06-2018, 10:49 PM | #2 |
Angewendet Ingenieur
Drives: 14 Camaro ZL1 Join Date: Apr 2015
When you say 02 sensors which ones? Original for your year of car? Check header gaskets at both ends?
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah. |
05-07-2018, 09:30 AM | #3 | |
Yes. They are the O2 sensors that match the VIN for the car. I have the cat-less JBA mid-pipes and stock exhaust manifolds for now. I have checked the connections. The stock manifolds have never been removed and I cannot detect any leak at the connection between the manifolds and the JBA pipes. When I smoke tested the car I only used the ~1psi that the regulator on the smoke machine allows. Do I need to allow more pressure into the engine for the smoke? Thank you for the response.
2010 L99 2SS
SLP TVS 3.2", AR LTs, SLP Blackwing CAI, ZL1 Pump, Jannetty FPCM, ID 1050-X |
05-08-2018, 09:16 AM | #4 |
When I log STFT, the values on both banks show between 0.98 and 1.01. Both banks stay within 2-3% of each other. However, the LTFT between banks has a delta of 10-12%.
Don't know. Guess I will do more work to find a leak this weekend. Is it unsafe to drive the car? Could I have done something wrong when installing the injectors?
2010 L99 2SS
05-08-2018, 04:48 PM | #5 | |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
05-08-2018, 06:50 PM | #6 | |
The fuel rail is torqued and no injector adapters. Gotta be a leak somewhere. I will try again to find it. Thank you
2010 L99 2SS
05-09-2018, 02:39 PM | #7 | |
We cap the TB and blow 10-15 psi in the intake to test all that. The exhaust is a little harder to test but black soot trails are the first indication. I would be looking at the Mid pipe to manifold connection by removing and looking for soot trails. You can have a friend with welding gloves try and cap the tail pipes with the car running while you look around under the car for leaks near the O2 sensor. A pin hole near the O2 sensor and really screw with the readings. Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com Last edited by JANNETTYRACING; 05-10-2018 at 07:18 AM. |
05-09-2018, 03:52 PM | #8 | |
Great info. Thank you, Ted. What do you use to cap the TB that can stay on with 15psi against it? My rubber glove won't quite handle that. Thanks again!
2010 L99 2SS
05-09-2018, 04:05 PM | #9 | |
Ted.
05-09-2018, 10:48 PM | #10 | |
05-10-2018, 07:19 AM | #11 |
Noticed a typo in the last sentence was suppose to be:
A pin hole near an O2 sensor can really screw with the readings.
05-10-2018, 09:07 AM | #12 |
Perfect. Thank you!
2010 L99 2SS
05-15-2018, 09:22 AM | #13 |
Just an update.
Resealed both of the mid-pipes to exhaust manifolds. Checked that the O2 sensors were sealed and searched for vacuum leaks. After this, LTFT at idle are Bank 1 0.90 and Bank 2 0.98 on SCT X4. Do those number give an indication which side likely has the leak? And, any clue to if it is on the exhaust or intake side? Thank you
2010 L99 2SS
