Old 12-13-2014, 08:10 PM   #1
11syn3rgy
JT Synergy RS/2SS
11syn3rgy's Avatar
Drives: 2011 Camaro RS/2SS (L99) Synergy
"Safe" boost levels for stock bottom end?
Hey guys,
I'm currently running 9.5 psi on my L99 Magnacharged Camaro. I plan to upgrade to E85 and pulley down next spring but I'd like to know how much boost a stock bottom end can take? I realize this is a loaded question and it depends on how hard I drive, but is 13 psi "dangerous" or can our cars live at this level? I drag race 5-6 times during the summer and I don't want to worry about racing it. Just trying to get a game plan. The E85 will give me plenty of octane and I'm already running ID850's so fuel shouldn't be an issue. Just trying to be smart.
Thoughts.
Thanks!
11syn3rgy is offline   Reply With Quote
Old 12-13-2014, 10:54 PM   #2
Bo White
Bo White's Avatar
I've been at 12 for a while and will be changing to the next pulley soon to crank it to 15psi.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 12-13-2014, 11:14 PM   #3
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
As long as your tune is spot on, you should be fine. Theres a car on here running 919whp on a stock short block. Youll never hit that on a maggie so throw everything you want at it!
2010 Camaro SS LS3 - No Modz
376LS3 is offline   Reply With Quote
Old 12-13-2014, 11:18 PM   #4
Bo White
Bo White's Avatar
Agreed. You mentioned injectors but what pump are you running?
Totalled:
Old 12-13-2014, 11:24 PM   #5
402
Drives: Camaro
As on any ls3/l99 I always recommend valve springs, unless it's already cammed, as I have witnessed valve float as low as "8 psi".
Other than that they are fairly stout from the factory as long as tune etc. Is spot on.
402 is offline   Reply With Quote
Old 12-14-2014, 01:24 AM   #6
camarossdusk
whippled 5th gen
Drives: 2013 camaro ss
agreed on spot on tune, been running 12-13 lbs on water methanol raced a few times at track already with water methanol injection no issues.
Whipple running 13 lbs of boost, Innovators west 8 rib with 10 percent over drive crankshaft pulley. Fore level 2 Dual pump fuel system, with duel TI auto fuel pumps, ID 1300 fuel injectors, tuned on e85. Driveshaft shop aluminum driveshaft, 1400 hp half shafts, Detroit tru-trac. ls9 camshaft, CNC ported heads, with trunion and dual valve spring upgrade, LS9 head gaskets, ARP 2000 head studs, Manley stainless valves. Adjustable Bmr toe rods, trailing arms, rear adjustable sway bar, full cradle bushings, upper control arm bushings, BMR diff. bushings, bmr driveshaft safety loop.
camarossdusk is offline   Reply With Quote
Old 12-14-2014, 03:40 AM   #7
11syn3rgy
JT Synergy RS/2SS
11syn3rgy's Avatar
Squash.
Old 12-14-2014, 03:42 AM   #8
11syn3rgy
JT Synergy RS/2SS
11syn3rgy's Avatar
Thanks guys. I think I'm good with my tune. Jannetty has been great!
Old 12-14-2014, 06:07 AM   #9
Bo White
Bo White's Avatar
No meth here. All pump.
Totalled:
Old 12-14-2014, 07:23 AM   #10
Unreal
Drives: 2006 Z06
Don't worry about boost, and more so about power. 12psi on a turbo, vs 12psi on a big centri, vs 12psi on a maggie is all different levels. Maggies have lower limits because of the hot IATs, and less efficiency compared to others.
Nick
Corvette Z06 -1200ish rwhp
Old 12-14-2014, 08:11 AM   #11
11syn3rgy
JT Synergy RS/2SS
11syn3rgy's Avatar
Makes sense. So, if you were me, where would you feel comfortable with the stock bottom end? What power level?
Old 12-14-2014, 08:41 AM   #12
Unreal
Drives: 2006 Z06
L99 6l80 car I wouldn't push it much past 650rwhp IMO. Tranny will start giving you issues anyways much higher than that.
Nick
Old 12-14-2014, 09:34 AM   #13
11syn3rgy
JT Synergy RS/2SS
11syn3rgy's Avatar
Ok, thanks again
Old 12-14-2014, 10:34 AM   #14
Js2fst
2010 transformer
Js2fst's Avatar
Drives: 2010 ss camaro
I am planning on a Procharger I worry about actual hp vs lbs of boost
Js2fst is offline   Reply With Quote
