08-07-2017, 03:58 AM | #1 |
Drives: 2015 Camaro 2SS Join Date: Oct 2016
Here's a strange electrical problem. :(
I loaded up the car to go to a local show less than 50 miles away.
However when I got there and went to restart, nothing, lights came on, no clunk or clicking, tried it 4 times, nothing. Left it an hour and it started fine, also seven hours later when I came to leave. I got back , put a volt meter across the battery, 14.5 volts with engine running. Its morning now, taken it for a run, got back and its charging around 13v got underneath alternator cable is very secure, as I suspect it could be alternator low charging or a crappy starter.. Not sure where the engine earth strap is to check it, but i'm on it. Obviously its the non start that worries me most, are these starters prone to heat soak or anything? Vehicle is a 2010 SS auto, stock, and with 13k on the clock. Battery is an Exide which I can't see being 7 years old, but have no idea of it's age. Any help or ideas i'm listening. thanks. Last edited by Gordo-D; 08-07-2017 at 05:23 AM. |
08-07-2017, 06:45 AM | #2 |
Voltage could be fine but cranking amps could be low meaning there is not much left of chargeable cell capacity. Do a cranking amp load test with a battery analyzer. You'd be surprised how what's left of a battery's cells can test fine from a volt perspective but be low in cranking amps.
Also, see this post http://www.camaro5.com/forums/showth...76#post9854276 |
08-07-2017, 07:02 AM | #3 |
no click at starter, but headlamps are bright, and battery voltage is ok, I would start with the starter relay at the engine fuse box. Are you getting a starter crank signal at the relay?swap relays with another one in the fuse box. but these rarely ever go bad. stick or automatic? clutch pedal switch ok? pedal needs to be applied for start up, but if switch is intermittent could cause a problem. You can jump the starter relay terminals of the fuse box when problem occurs have it in neutral if a stick. you can see if you have starter signal power at starter relay when the key is turned on to start position. I would do this first.
2012 zl1 stock 7000 miles
2010 TVS2300, BTR cam PD stage 3, ID1050 injectors, CHE bronze trunnions, 7.400" pushrods,.660" lift platinum springs, Titanium ret, Zl1 fuel pump, Kooks LT headers, High flow cats, Roto Fab CAI, Corsa exh., Mellings oil pump, HD chain, ls2 damper, all synthetic, BMR control arms, zl1 toe link, BMR cradle mounts, W/bottle relocation, air scoop deflector, Hennessy wheels, two piece rotor, morimoto fogs, DRL harness, coilovers, Heads up install, mgw shifter, slps splitter, slp spoiler, zl1 side skirts, painted strips, debadged, tinted, 2018 emblems. Edit Signature |
08-07-2017, 07:05 AM | #4 |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
OP: Your overthinking this imo... Just replace the battery and I bet you will be good to go.
08-07-2017, 07:12 AM | #5 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
+1...battery first and make sure it is a AGM version...and clean all grounds...good luck!
08-07-2017, 07:13 AM | #6 |
Thanks, no wonder I couldn't see the earth wire.
The heat shield stuff is a good idea. What is AGM by the way? Sorry, its Auto and L99 Here is a small video of me starting the car, its always sounded a bit lazy. https://vimeo.com/228652224 |
08-07-2017, 07:22 AM | #7 |
old school chevy rodder
Heat is also a great way to show the battery is failing as its not just cold that shows a weak battery, and I get some starter heat stroke now in the summer. Of course I have headers and my only additional cooling is from removing the center section of the hoods insulating strip at the firewall to vent air. I have blanket to wrap the starter, and someday will have to do hood venting.
Most likely yes it is the battery, load testing it may not show how strapped it is unless under the same conditions but should show its weak with less than advertised rating as I always find batteries last 1/2 their advertised life strong then after that its a crap shoot. My car always sounds a little lazy starting even with a new starter and battery and its not in the tune according to my tuner the timing is not too far advanced.... And I have checked and sanded and done everything I can to the grounds. I if way too hot for restart will actually drag the starter real slow and it will start but throw codes I have to clear disconnecting the battery to clear them as it goes into rich mode until I get a point to let her cool down and reset and have checked the new battery and its fine........
08-07-2017, 07:51 AM | #8 | |
08-07-2017, 08:04 AM | #9 | |
Drives: 2014 2SS/RS Join Date: Dec 2014
After sitting a couple hours to dissipate the surface charge, if there is no degradation or short in the plates, it should read 12.6 volts before starting. As others mentioned the auto stores can do a free load test.
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
08-07-2017, 09:00 AM | #10 |
Thank you all so far.
That battery date code is really useful, I rang Exide over here but they couldn't help although they did their best. |
08-07-2017, 09:08 AM | #11 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Your start sounds perfectly normal to me. Since you go from that to a no start situation, I would think it's most likely an intermittent ground strap issue. The battery could likely be on it's last legs, but I doubt it would go from 60-0 like that. Wouldn't hurt to have the battery tested just the same. Low battery voltage issues create some wild symptoms in modern cars....
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
08-07-2017, 09:11 AM | #12 |
The only stamped code is on the top.
Its 3JC04L2 so if 04 is the month, what is L2? I am of the opinion that 0 is for 2010 having read up even more, it would fit with the cars age. Last edited by Gordo-D; 08-07-2017 at 09:30 AM. |
08-07-2017, 11:41 AM | #13 |
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
As other's have said, it that is the original battery, it is over 6 years old and is most likely the issue. To be sure, take it down to the nearest auto parts store and have it load tested.
08-07-2017, 12:19 PM | #14 |
Tried testing it and it seemed ok, however I have just purchased a new battery and will report back.
I agree, if its the original battery even if that isn't the problem, 7 years is at the limit. Thanks all. |
