09-04-2017, 08:38 PM | #1 |
Drives: Camaro 2ss Join Date: Aug 2017
Winter tires and rims, size and brand recommendation?
Hey, I am looking for some winter boots for a gen 6 camaro ss. I cannot find tire sizes that would match the back end.
Can someone recommend size and brand. I was originally looking at blizzaks but they don't make them in 275. I am new with cars in general forgive my ignorance. I would also like to stick to 20in tires. I am on Vancouver Island, winters are avg 0c + or - 5-8c Thanks. Last edited by Dajaga; 09-04-2017 at 09:03 PM. |
09-04-2017, 09:34 PM | #2 |
Drives: 2016 Camaro 2SS Join Date: Dec 2015
I found that you can get 19x8.5" wheels with 245/45 winter tires for $200 more than a set of just tires in stock SS sizes... considering you'll have to shell out the $1500 for stock sizes every time you need new tires and half of that for the smaller ones, it just doesn't make sense. But I think Pirelli make a set, check tire rack.
09-05-2017, 08:02 AM | #3 |
Drives: 2022 2SS A10 NPP MRC Red Hot Join Date: Aug 2016
+1 on the 19x8.5 wheels with 245/45/19 snow tires.
FWIW I am running Pirelli Sottozero 3 for snow driving. A separate set of wheels and tires makes the change over simple in the garage or driveway. |
09-05-2017, 08:28 AM | #4 |
Drives: 2016 1SS (12/10/2016) Join Date: Jul 2015
I also recommend buying a second set of wheels/tires... way cheaper in the long run.
Get a square setup so you can rotate. I have a 1SS with the regular 4 piston Brembos and 18" wheels fit great. Set of 4: Wheels: 18 x 8 with 35 offset Tires: 245 / 50 R18 Blizzak WS80s Pictures of the setup I went with here: http://www.camaro6.com/forums/showth...=430064&page=7 |
09-05-2017, 09:27 AM | #5 |
Drives: 2017 2SS Join Date: Apr 2016
I've read a bit into the data from TireRack and it seems to me that the Pirelli Sottozero 3 tire is the best price/performance winter tire available. I intend to get that and a dedicated (cheap) winter wheel. Before I commit to this I will check into Costco for their price on Michelin Pilot Alpin PA4. I was able to get a good price on PS4S in stock size from Costco, so I am hoping they can do something for me here as well.
Wider tires are NOT better for snow, so sticking to the stock SS size tires should be avoided if possible. *EDIT* Costco did not do me any favors on the Michelin Alpin PA4. Their price was around $270 per tire, and TireRack has them at $236. *EDIT2* I ordered a set of 18" Sport Edition P5 Wheels, Camaro RS TPMS (Half the cost, but lower speed rating), and 245/50R18 Pirelli Sottozero Series 3 Run-On-Flat tires from Tirerack. *EDIT3* I have had the Pirelli Sottozero 3 installed for a few weeks now and they are fantastic! They are much quieter than I expected. Noise is not at all an issue with these tires. So far I have not encountered any snow. I do not look forward to when the snow comes, but I am hopeful these tires will do well. The worst weather I have seen with them so far has been cold heavy rain and the performance from the tires was exceptional.
2017 HBM 2SS A8|F55|NPP|H01|IO6|RIK|WGL|56R
09-05-2017, 10:06 AM | #6 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
That's exactly what my winter setup is. Works great.
2017 "M1SS1LE" in Hyper Blue w/PDR
09-05-2017, 11:59 AM | #7 |
It should be 245/50 for 18" wheels, otherwise the wheel diameter will be noticeably smaller.
09-07-2017, 12:32 PM | #8 |
Good catch, thanks!
09-07-2017, 05:45 PM | #9 | |
Drives: 2016 Camaro RS 1LT 2.0L Turbo Join Date: Apr 2016
I have to deal with -30°c and lots of snow so I'm running Hakkapeliitta 8's studded on my oem rims (245/40/20).
'16 1LT 2.0T RS - Catless DP, Intake, Tune/ Eibach springs FE3 shocks/ BMR front bar FE4 rear bar/ Xpel'd front end, CP Reload sealed/ Radenso Pro M.
09-13-2017, 04:45 PM | #10 |
Drives: 2017 Camaro 1LT 2.0 Turbo Join Date: Nov 2016
245/50-18 all around with Michelin Ice x3.
We drove in the Alberta winter land on these, felt safe and secure. Recommend. |
09-23-2017, 10:40 PM | #11 |
Drives: Camaro 2SS Join Date: Jan 2017
@Tankman - Did you drive your Camaro last winter? I live in Calgary and before I spend thousands of dollars on tires and rims I want to make sure the car is drive-able in the winter. I have an SUV for really snowy days, but that one needs new winter tires too....
2017 2SS stock
11-03-2017, 06:29 AM | #12 | |
Yes it was our daily driver in town. Snow/ice mode.........etc |
11-11-2017, 02:29 PM | #13 |
Drives: 2018 1LT Camaro Join Date: Aug 2017
11-14-2017, 07:39 PM | #14 |
We drove according to conditions so we obviously would slow down or avoid any terrible winter conditions or areas.
Generally speaking it didn’t stop us, slush: we probably approached it a little faster to force through it. Hope this helps? |
