10-07-2017, 10:35 PM | #1 |
Drives: 2002 Camaro SS Join Date: Oct 2007
Aux Gauge pack cluster mod
Am I the only one that feels that the more important gauges are behind the less important ones and their view is blocked by the HVAC controls? Has anyone tried to rearrange the gauges in bezel so that oil pressure and voltage are in front?
Sent from my SM-G920V using Tapatalk |
10-08-2017, 04:41 AM | #2 |
10-08-2017, 08:49 PM | #3 |
Drives: 2011 Camaro LS Join Date: Apr 2017
I don't see why it wouldn't be possible, but being that they're stepper motors, that's 4 wires per gauge... A lot of rearranging.
Then there's the bezel... I'm sure it's one piece like the main gauge cluster. |
12-22-2017, 05:51 AM | #4 |
Drives: 2015 Camaro SS 1967 Buick GS 400 Join Date: Dec 2017
Wiz, great question. Did you move any gauges around yet? I will be considering this option myself in a few months.
02-04-2018, 05:50 PM | #5 |
Sorry for the delay, haven't been checking this forum, but the short answer is no too many other things going on. Let us know if you give it a shot.
02-04-2018, 06:25 PM | #6 |
'It's an experiment'
I did this instead, 16 parameters available:
-Don
747 RWHP 794 RWTQ
06-16-2018, 04:43 PM | #7 |
Drives: 2014 Ashen Gray Convertible Join Date: Apr 2017
Thought I would bring this topic up once again. I really like to occasionally check the oil pressure when driving, a habit I have had for years. Problem is you really can't see it without bending over in the seat. If the oil pressure gauge was moved over to the upper right side you would have a clear view.
Has anyone tried this? If so pictures?
06-17-2018, 09:33 AM | #8 |
Drives: '23 LT1 A10 Join Date: Oct 2015
Can this be mounted on the dash?
24 LT1 M6 Sharkskin Metallic
06-23-2018, 11:44 AM | #9 |
Drives: 2011 Camaro SS Join Date: Nov 2017
I finally took the time to really look at how the gauges are laid out and each gauge housing has a rounded corner specific to its location so unless you can disassemble the gauge and move them to a different housing I don’t think you can change the location.
My Little Mid-Life Crisis Cure!
First - 1997 Camaro 3800 Y87, M5, Green - Gone | Second - 1997 LT1 Z28, M6, Silver - Sold | Third - 1999 LS1 Z28, M6, Pewter, Almost Stock! - Sold Current - 2011 Camaro SS, M6, black, 1LE suspension parts - Current |
07-29-2018, 07:05 PM | #10 |
Has anyone added a gauge pod with an auxiliary oil pressure gauge to the A post? There has to be a way you tap into something to add another oil pressure and temp gauge? I have a two gauge pod in my 96 Impala SS that I really referrer to more than anything.
07-29-2018, 08:22 PM | #11 |
The data is easily available over the single wire CAN bus, so any gauge that can get data over CAN can add those gauges. (that was a lot of cans! )
Personally, I have a selection of data that I can cycle in the DIC navigation page: Coolant temp, oil temp, oil pressure, trans oil temp, intake air temp, fuel tank level (in percent, useful for when the gauge gets way down), and outside air temp (just 'cause). |
08-01-2018, 07:21 PM | #12 |
Drives: 2009 ZR1 Join Date: May 2010
MopI have an NGauge that plugs into OBD port and it shows oil pressure. I also have a PLX gauge plumbed to AFR, fuel pressure at rail, and oil pressure at oil cooler block. I compare the oil pressures and they are generally within 1 psi of each other at start up. After warming up, the PLX shows a few psi higher. I am not sure why. Perhaps because the PLX is reading from a lower spot on the engine whereas the OBD is reading from the sensor at the top, rear of the engine. It could also be the sending unit I am using for the PLX isn't accurate. I don't know and it really doesn't bother me.
The ngauge is in the ac vent and the PLX is in an A pillar pod with my eboost2. They look out of whack in the picture but are straight when viewed while driving. Last edited by blake-b; 08-03-2018 at 01:49 PM. |
09-25-2018, 10:13 AM | #13 |
Drives: 2015 Camaro SS 1967 GS400 vert Join Date: Nov 2017
I haven’t bought the 4 pack gauge cluster yet but in the meantime I am trying to figure out what the bars represent in the information center. Meaning, does 2.8 (3 bars) = 50 psi? The dopes at chevrolet can’t answer and keep referring me to the manual. Am I missing this in the manual?
Then they told me to contact the dealer. The dealer told me to look on the inside of the door jam for tire pressure psi. Does no one listen anymore? Anyway, has anyone figured this out? |
09-25-2018, 05:03 PM | #14 |
Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
Not sure why they put BAR instead of PSI on the DIC, but it is the metric form of pressure.
So 1 BAR = 14.5 PSI or so |
Thread Tools | |
