Old 07-19-2017, 03:29 PM   #1
2Intense
Drives: 2015 Camaro RS
Help-Front End "Shimmy" over 75MPH
Anyone ever have a shimmy they couldn't solve...
2Intense is offline   Reply With Quote
Old 07-19-2017, 06:46 PM   #2
MA2010SS
Drives: 2010 Camaro SS
Where is the shake?? in the steering wheel or in the seat??? Front tire sustained visible damage but what about the rear?? Is that damaged on the inside of the wheel?
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
MA2010SS is offline   Reply With Quote
Old 07-19-2017, 07:09 PM   #3
2Intense
It nicked the side wall on the right rear tire but no damage to the rim or anything, I replaced the tire. The damage in the photographs above are of the outboard bead seat of the rim. The shimmy comes from the right front of the car I can feel it in the wheel more so than the seat.
Old 07-21-2017, 12:37 PM   #4
2Intense
Anyone have any thoughts or suggestions ?
I'm stumped!
Old 07-21-2017, 04:54 PM   #5
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Steering rack is probably damaged. Not good at all.
Scott@Bjorn3D is offline   Reply With Quote
Old 07-21-2017, 05:14 PM   #6
krusher
krusher's Avatar
Drives: 2010 Camaro SS/RS CGM
What about wheel bearing?
krusher is offline   Reply With Quote
Old 07-21-2017, 05:15 PM   #7
2Intense
I was wondering if it could be wheel bearing too....
Old 07-21-2017, 09:37 PM   #8
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
I would check the new parts first. Have the wheel and tire road force balanced to verify the wheel is round and the tire not defective. A good tech that knows how to use the machine can diagnose even more issues with the wheel and tire. Start there.
Old 07-22-2017, 07:07 PM   #9
2Intense
Wheel and tire will check today and they checked good. I went ahead and had the right front wheelbearings replaced with OEM parts. Problem remains.
Really scratching my head now. The mechanics feel if it were the rack and Pinion that I would feel it regardless of the speed. Starting to wonder if that bump to the rear tire did something to the Rear axle.
Old 07-22-2017, 09:53 PM   #10
JusticePete
Check the rear wheel and tire as well.
Do you have alignment specd?
Old 07-22-2017, 10:17 PM   #11
2Intense
Rear wheel at tire are new, I replaced both Front and rear right hand wheels and tires. It's been aligned each time after I have changed a component (4 times in last two weeks) and all well within specs..
Old 07-23-2017, 10:47 AM   #12
JusticePete
Both rear wheels and tires tested well on the RF machine?
Did they give you a print out?
Old 07-24-2017, 06:33 PM   #13
krusher
krusher's Avatar
Did you have them road forced balanced though? I had a hell of a time once with a new tire. Had it balanced at 4 shops. Finally i got it to a point where it was still there but bearable. Later the tire must have worn in and the problem went away. Try changing the wheel from one side to the other and see if the prob follows. Might be like me and have a crap new tire.
Old 07-24-2017, 07:36 PM   #14
JusticePete
It happens and Road Force Balancing by a tech that know how to use the machine does far more than just balance.
