05-12-2017, 01:43 AM | #1 |
680rwhp zl1 vs 600 whp gtr
Hello guys, i got called out locally to run a 600 whp gtr from a 30 roll. I've never raced one before but i know they're legendary, do i have a shot against him with 80 more hp? he's on stock wheels/tires and i have 17" welds with m/t et street r 305/45/17 wrapped on them both auto!
05-14-2017, 02:23 PM | #2 |
Drives: 2012 2SS 45TH Anniversary Join Date: Mar 2012
Unless the driver has very very little experience, no. GTR's have extremely efficient trans and suspension. Usually you will need quite a bit more hp to beat one. Of course, there is only one way to know for sure..
PFADT stage 3 suspension kit, SW LTH, SW cat less retro exhaust, MGW short throw, 3.91 gears, MRR Z28 wheels, Roto Fab CAI, SLP underpully, 255cc ported heads, TSP 229/236 Cam, ZL1 pump, Street Slayer Twin Carbon clutch, ID850 injectors, Snow Stage III Meth kit
480whp/460wtq tuned by Dynosty |
05-15-2017, 09:47 PM | #3 |
Drives: Z06 wannabe Join Date: Feb 2015
Yea.... 600rwhp from a roll and he is already in boost..... Id have to edge to the GTR.
I would like to see how it goes! Just maybe don't put money on it.
Apex Focused
05-15-2017, 09:56 PM | #4 |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
Drivers race, go for it
05-15-2017, 10:24 PM | #5 |
i pulled the trigger and agreed to the race, i also got him to do 2 runs 1 from a dig and 1 from a 30 roll. i'll try to get my gopro set up so i can get a vid for you guys. should be happening next weekend.
06-19-2017, 10:48 AM | #6 |
run him. from a roll, it's basically who makes peak power quickest. auto / tires will have less effect on the outcome.
Robert
12.012 @ 115.75mph DA: 2371 | 486rwhp/467rwtq (11/8/2015)M 11.265 @ 123.55mph DA: 2318 | 526rwhp/532rwtq (11/19/2016)M 10.722 @ 132.21mph DA: 850 | 645rwhp/581rwtq (12/3/2017)M 10.609 @ 130.19 DA: 975 | 675rwhp/629rwtq (2/16/2020)D Build: E-Force w/ 3.25" pulley (11lbs of boost), 10% OD under pulley, Fore Dual Fuel System, ID850's, AEM CAI, Borla Long Tubes, Flowmaster Super 10's, Circle D 3200 converter 258mm triple disc lockup, cam 226/242 116+4 LSA, ZL-1 Rear end, E85 & BRC Raceworks Tune (previously known as CMS) Youtube Channel: http://www.youtube.com/c/RobertMitchellRCM |
06-19-2017, 03:08 PM | #7 |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
I never understood the desire to do roll runs, especially against a turbo car. It gives them all the advantages. Please post the videos.
06-19-2017, 03:24 PM | #8 |
Drives: 2010 2SS/RS L99 IBM silver stipes Join Date: Dec 2015
2010 Imperial Blue w/ Silver stripes 2SS/RS L99
Mods = Not enough.... |
06-19-2017, 04:27 PM | #9 |
Drives: ZL1 Join Date: Oct 2012
With your car being an auto and if tuned properly the way the root charger turn up, it should be a great race with the edge to you. I have a buddy that does have both cars (ZL1 and GTR)and actually the GTR is more dangerous off the line due to being all wheel drive. The weight on both are close to one another as well.
06-19-2017, 04:42 PM | #10 |
Drives: 2011 ss Join Date: Sep 2015
Subscribed to see outcome.
06-19-2017, 08:02 PM | #11 |
Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
From a roll is probably your best bet. They are auto only so he wont have to worry about shifting and he will already be in boost, but so will you with your supercharger. Pray that 80 more HP is enough to fight his weight advantage. Godzilla off the line with that AWD launch control is no joke. I don't see you winning that at all. Good luck, post the results!
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
06-19-2017, 08:12 PM | #12 | |
06-20-2017, 12:55 AM | #13 |
It would be nice if OP listed the year of both his ZL1 and the contenders GT-R for reference. Also would be curious as to the discrepancy of posting that his ZL1 has 680 to the wheels but in his "drives" section it says 653rwhp? For his sake, I would hope that it's the 680rwhp that reigns true.
From a dig I'd say it's hopeless. Reasoning is because a stock base GT-R does a 0-60 with launch control in 2.9 seconds with 545 crank HP. Where as the later model nismo's have 600 crank HP and do it in 2.7 seconds. Factor that ridiculously quick 0-60 time in after the parasitic drivetrain loss of it being both auto and AWD. If OP is suggesting that this GT-R has 600 to the wheels, cut that quick time down even more provided traction isn't an issue. A roll race really is your only bet. Even then, your supercharger isn't as good in top end power like the twin snails the GT-R has is. I don't see you winning either one, but a roll is gonna be your best bet. Keep us posted!
06-20-2017, 11:20 PM | #14 |
Drives: 2012 GT500 SVTPP Join Date: Nov 2009
I would give you the advantage. You have a much better power/torque to weight ratio, and his awd will be less advantageous from a roll. You both have an auto, so your challenge is not to blow the tires away from that speed. I would even say it could be a drivers race from a dig if you can launch well with your tire set-up.
Past rides:
2002 BMW M3 2010 Camaro V6 2010 Camaro SS L99 2011 Camaro SS Ls3 2011 Dodge Charger R/T 2012 Dodge Charger SRT8 Super Bee/ Reso Delete Current ride: 2012 GT500/ 2.3 TVS, Afco Dual pass heat exchanger, Roush Extreme Exhaust: 606 rwhp/ 611 wtq |
