Old 02-23-2015, 06:32 PM   #1
12TX2SS
12TX2SS's Avatar
Drives: 2012 2SS
Starting LSA conversion
well I went ahead and pulled the trigger. Bought a nice used LSA lower unit and ordered the conversion kit from Andy a ADM. Ive also ordered a new ZL1 fuel pump, magnuson heat exchanger for the camaro, and FIC 72lb injectors. Of course the injectors are 72lb@ 3bar, so will actually be 81lb@4 bar on my car. Im keeping my cam I have now and see how wel it does. it has 0 deg of overlap and is on a 114+4 lsa, so i think it will be fine. Went ahead and ought injectors that I had room to grow into to! I forsee several pulley changes. Ill update thread as I progress.
2012 2SS AGM, Roto Fab,Stainless power headers, Corsa ZL1 exhaust, LS3 conversion, Cam Motion 224/232 615/604 114+4, Wheatley Tuned, custom gloss black CCW Drag Pack
12TX2SS is offline   Reply With Quote
Old 02-23-2015, 09:24 PM   #2
Wayniez
Drives: 69 Camaro with LSA
Nice! Good luck with the build.
69 SS/RS Camaro complete frame off new sheet metal. DSE mini tubs, frame connectors, tubular control arms. Ride Tech 4 link with coil overs and Chassis Works Fab 9. C6 Z51 Corvette brakes. GM crate LSA/4l85 crate drivetrain.
http://www.lateral-g.net/forums/showthread.php4?t=17217
Wayniez is offline   Reply With Quote
Old 02-23-2015, 09:25 PM   #3
hammdo
'It's an experiment'
hammdo's Avatar
Congrats! A6 or M6?
LSA on the cam may be tight. I'm 112 and the idle and cold start is rough. Vacuum is low on startup and brake peddle is hard..
Good luck!
-Don
747 RWHP 794 RWTQ
Old 02-23-2015, 09:53 PM   #4
12TX2SS
12TX2SS's Avatar
Drives: 2012 2SS
a6..... itll be ok. cams been in the car for several months.
Old 02-23-2015, 09:57 PM   #5
hammdo
hammdo's Avatar
I see, you're not VVT. Can't wait to see this!
-Don
747 RWHP 794 RWTQ
Old 02-23-2015, 10:04 PM   #6
12TX2SS
12TX2SS's Avatar
Drives: 2012 2SS
no sir no vvt. yes im pretty excited. ive looked at your detailed thread several times, helped me make the decision!!
Old 02-24-2015, 06:42 AM   #7
ADM PERFORMANCE
Drives: Anything I want
This car will be very strong
ADM PERFORMANCE is offline   Reply With Quote
Old 02-24-2015, 07:50 AM   #8
hammdo
hammdo's Avatar
+1!
Hope my build thread helps. This one should be an easier one than mine!
I experimented on mine and will probably do a few more just for my education.
Can't wait to see this one...
-Don
747 RWHP 794 RWTQ
Old 02-26-2015, 06:19 PM   #9
12TX2SS
12TX2SS's Avatar
Drives: 2012 2SS
all my parts are here, but im super bummed. The bearings in the snout of the blower I purchased are bad and are making noise. Hope this is an easy fix. Anyone have an idea of who to contact to get them replaced?
Old 02-26-2015, 07:02 PM   #10
hammdo
hammdo's Avatar
I thought those could be repacked with the 'blue' lube. Andy will know if that may work. Also, there is a thread on how to update the coupler etc. it may also have some info...
http://www.camaro5.com/forums/showthread.php?t=313908
-Don
747 RWHP 794 RWTQ
Old 03-04-2015, 08:54 PM   #11
12TX2SS
12TX2SS's Avatar
Drives: 2012 2SS
new bearings installed as well as lpe hub and 2.55 pulley! Was able to get it done here locally at G Force. Autometer Cobalt fuel psi, boost gauge and dual pillar pod ordered!
Old 03-06-2015, 12:24 AM   #12
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Where can you buy new bearings at for the LSA?
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 03-06-2015, 06:00 AM   #13
ADM PERFORMANCE
We can sell them to you as well.
Old 03-06-2015, 06:01 AM   #14
ADM PERFORMANCE
I forgot about mike and them,the wittle these things up all the time.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
