Old 09-01-2015, 10:36 PM   #1
onebad1le
Drives: 2013 1le
15lbs of boost on stock ls3
well currently running 12.9 lbs of boost with 2.55 pulley on LSA
changing too 2.38 pulley and 15 lbs of boost
the diff from 2.85 too 2.55 was a big diff aka ---(hellcat beater)
hope theres the same diff from 2.55 to 2.38 will post results later
and hope my stock block can take it
onebad1le is offline   Reply With Quote
Old 09-01-2015, 11:07 PM   #2
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
How are you making 13lbs with a 2.55? I'm seeing 10.5 up top with a 2.50?
Either way, should be badass man!
12 camaro ss- 416LSX,TH400, 98mm GT55 turbo, M1 Fuel, cable drive fuel system, 17 injectors, holley dominator, 8.10 cert, backhalf, Ford 9", 33x17x16 tires, 1620rwhp
ttshovel is offline   Reply With Quote
Old 09-01-2015, 11:19 PM   #3
onebad1le
Drives: 2013 1le
boost
my set up might be different then yours
I have ls9 cam no overlap ,bigger cam makes less boost
also heads and snout ported
what your set up? I rather have 10 lbs of boost and more power
when i upgrade to BTR stage 3, I think i will loose boost but
gain power.
Old 09-01-2015, 11:27 PM   #4
ttshovel
ttshovel's Avatar
Gmpp ported ls3s with ls9 gaskets net me 10.9:1 compession, 2 inch headers, untouched blower, and btr stage 3 pd cam.
The difference in our cams explains it
Old 09-01-2015, 11:31 PM   #5
onebad1le
Drives: 2013 1le
Did u ever have another cam in ? how much power did u gain with BTR 3 ?
Old 09-02-2015, 01:26 AM   #6
ttshovel
ttshovel's Avatar
Ive had 2 others in the car but not with the lsa blower.
I gained 213whp with the blower and cam swap though.
Old 09-02-2015, 03:09 AM   #7
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
another factor is elevation. Houston is about 45' above sea level, whereas Findlay, OH is almost 800'. The BTR cam has negligible overlap (1/2*), so I wouldn't think that it would make a big impact on boost pressure.
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 09-02-2015, 03:42 AM   #8
ttshovel
ttshovel's Avatar
Ah, didn't think about elevation
Old 09-02-2015, 08:16 AM   #9
onebad1le
Drives: 2013 1le
It not just over lap. - its the duration the valves are open
Old 09-02-2015, 10:32 AM   #10
williamp78
williamp78's Avatar
Drives: 2011 2ss blk/wht strp
ran mine last fri at RPR and my 16psi is holding just fine. Good luck
2011 2ss black/wht stripes
"CAM only"
https://www.instagram.com/w_j_p_boss/?hl=en
williamp78 is offline   Reply With Quote
Old 09-02-2015, 11:49 AM   #11
D3R3K
Sittin side ways
D3R3K's Avatar
Drives: 2010 2SS/RS IOM
I've been running this pump gas/meth tune for 9 months with no problems. I've got a smaller pulley for my race gas set up. The cylinder heads have never been off.
850+hp club member
Procharger F1-A
D3R3K is offline   Reply With Quote
Old 09-02-2015, 12:20 PM   #12
onebad1le
Drives: 2013 1le
I'm running zl1 pump and 1000cc injectors
When I install pulley will see when I run out of pump
What fuel system u running
Old 09-02-2015, 01:44 PM   #13
bct10985
Drives: 2010 2SS LS3, 2013 duramax
That makes me want to crank mine to the max.
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 09-02-2015, 06:07 PM   #14
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
The real issue is past 20 pounds of boost, from what I hear from respected shop owners and engine builders, that's when you risk pushing water. You'll never get to 20 psi on a non forged bottom end, but the point is pay more attention to your whp than your boost.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
