Old 04-08-2021, 02:32 PM   #1
KevinHoward8509
Drives: 2014 camaro ss 1LE
lets talk mufflers and drone
I currently have kooks long tubes with a hallowed out cat setup with kooks mufflers. its 3 inch all the way back.
I need to stick with 3 inch but it drones like a MFER
is there a muffler out there everyone likes that wont drone so damn bad?
2014 SS 1LE summit white
Car made 675/560ftlbs
Modifications are as follows:
Engine, Procharger P-1 Stage 2 Kit Intercooled, HP Tuner, AEM Wideband with Gauge, TSP Supercharger Camshaft 224/240 .615/.615 112 +3, Brian Tooley Dual Valve Springs, Brian Tooley Chromoly Pushrods
Brian Tooley Titanium Retainers, GM 3 Bolt Conversion, New GM Oil Pump, Injector Dynamics ID 1050x Injectors, Kooks 1 7/8" Long Tube Headers , Kooks 3" Catted (Hollowed Out), JBA Power Cable Ignition Wires, Mishimoto Aluminum Radiator, Mighty Mouse Oil Catch Can, Edelbrock (Red) Valve Covers
KevinHoward8509 is offline   Reply With Quote
Old 04-08-2021, 03:32 PM   #2
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2014 Camaro 1SS RS SIM
Try a resonated x pipe, should help with drone.
2014 SS - BTR Stg 2 Cammed L99 1SS/RS FBO - "AleSSandra"
SSEssence is offline   Reply With Quote
Old 04-08-2021, 03:52 PM   #3
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
Corsa has a 3” system and they’re said to be drone free. Also, you might look into Solo’s J pipes. They cancel out resonate frequency so that the car won’t drone.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 04-08-2021, 03:54 PM   #4
Avenging Orange
Avenging Orange's Avatar
Replace cats...or...resonated x pipe....and/or...I have Borla Touring mufflers. Granted the touring mufflers are quieter, but have a nice deep mellow sound..and no drone.
Good luck.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 04-08-2021, 04:37 PM   #5
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2013 Camaro 2SS 2015 LaCrosse
Get Corsa axle back. Zero drone. Life is good.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is online now   Reply With Quote
Old 04-08-2021, 04:38 PM   #6
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
No x pipe? It will sound and perform so much better and reduce drone
2012 Camaro 2SS/RS - K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, DynoSteve tune, tru cool 40k trans cooler, apex scoop, heritage grill, jre dipstick mod
Complete street performance appointment booked - Cam, tsp CNC heads and converter.
Bigdumogre is online now   Reply With Quote
Old 04-08-2021, 07:12 PM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
^^^ this for sure!!
TSP STAGE 3 CAM,231/246 @112 LSA 614/641 LIFT, CIRCLE D 5C-4200-4500 CONVERTER,LOD INTAKE.CORSA EXHAUST. DSS 1 PC DS. PEGASUS SOLID CRADLE MOUNTS. 486RWTQ/475RWHP.LOTS MORE.
Old 04-08-2021, 09:14 PM   #8
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
Axle back? Only cat backs are made for the 2010. Or that’s all I have found.
Custom ground Texas Speed high lift cam, CAI intake, Bo White ported throttle body, Texas speed long tube headers, SLP loudmouth exhaust, MGW shifter, elite engineering catch can.
Camaro2ss2010 is online now   Reply With Quote
Old 04-09-2021, 08:45 AM   #9
KevinHoward8509
i pulled the hallowed out cats and had some race bullets installed but did almost nothing reduced it slightly was nasty up until about 85 and now its only nasty up to about 80. she pops alot more for some reason which i like haha.
Old 04-09-2021, 09:52 AM   #10
Modernmusclecar
Drives: 2010 Camaro SS
You need mufflers that produce a higher tone. Spintech sounds great Corsa or Borla are good as well. But those Spintechs sound nasty. They are loud tho.
EPS CUSTOM GRIND BLOWER CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBES HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3200 STALL....391 GEARS ..NITTO 555R 305 35 20 DRAG RADIALS..AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
Modernmusclecar is offline   Reply With Quote
Old 04-09-2021, 10:20 AM   #11
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
I have TSP long tubes and there 3" exhaust system with mufflers and have no drone. Before this I had a resonator and muffler delete on the 2.5" factory exhaust and now it's actually quiter on the highway with the TSP exhaust.
afm delete, GPI SS1 Camshaft with vvt, GM Performance Racing lifters, Comp CAMS trunnion upgrade, TSP Chrome Molly pushrods, TSP polished .660 valve springs, Melling 10355HV oil pump, Cold Air Inductions cai, TSP 1 7/8" longtubes with 3" exhaust
morepowerjoe is offline   Reply With Quote
Old 04-09-2021, 11:10 AM   #12
InFiD3ViL
InFiD3ViL's Avatar
Does Corsa even sell an axle back for our cars? I have looked for the Xtreme mufflers in an axleback version but all I ever seem to find is full catback setups.
2010 CGM Camaro 2SS LS3 Swapped A6 - GPI LS3 SS1 .647/.638, (224/237, 112 +4) on CamMotion 8620 core, BTR Platinum .660" Dual Spring kit w/titanium retainers, CHE bronze trunnion upgrade, stock heads milled @ .015, Melling HV 10296 oil pump, TSP long tube headers (W/Catless Off-road Pipes), FlowMaster Outlaw axle back/X-Pipe, Stage 2 Ported Throttle Body, Vararam OTR CAI, Mike Norris Gen 2 catch can + GM 1LE clean side separator, 160º thermostat - Megan Racing adjustable coilovers (lowered 1.75"), Firestone Firehawk Indy 500s - Tuned by Ryan @ GPI via HP Tuners
Old 04-09-2021, 11:11 AM   #13
TheFlyingBananaSS
Try their website. I thought I saw them in there last year.
Old 04-09-2021, 11:27 AM   #14
InFiD3ViL
InFiD3ViL's Avatar
Ok, will do. I thought I only saw them for the 6th gen.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
