Old 04-11-2021, 01:48 PM   #1
Avenging Orange
Avenging Orange's Avatar
Moan n groan
Had my new 3.91's for a bit...got 500 miles on em and changed gear oil. Did a little driving and a few figure 8's. When doing this they got a lot of groan. Is this typical of new gears?
Thanks
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 04-12-2021, 07:32 AM   #2
Modernmusclecar
Drives: 2010 Camaro SS
Thanks
No..when I had my gears done I drove right to the drag strip. Zero noise. Did have some sound late last year that sounded like rubbing. Changed the gear oil and now no noise. Something is not right.
EPS CUSTOM GRIND BLOWER CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBES HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3200 STALL....391 GEARS ..NITTO 555R 305 35 20 DRAG RADIALS..AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
Modernmusclecar is offline   Reply With Quote
Old 04-12-2021, 07:53 AM   #3
Inferno dogg
Inferno dogg's Avatar
Drives: 2010 Camaro 2SS
Thanks
My Yukon 3.90 gears scream at me!!! I also have heavy duty diff cover and poly bushings.
GPI SS3 cam with top end goodies,Circle D 4c 3800 w/Derale trans cooler kit sold by GPI,3.90 yukon gears,Kooks long tube headers,Roto fab cold air intake, Corsa extreme 3" cat back, Dyno tuned by Andrews Auto Georgetown MI, Heritage Grille, T4 splitter with under tray, Anvil spoiler,MRR 228 reps with Nitto NT555G2 tires 315 rear 275 fronts,BMR poly bushings,HD Diff cover from RDP,Raytech install kit
Inferno dogg is offline   Reply With Quote
Old 04-12-2021, 08:53 AM   #4
gtstorey
Are you sure your gear oil is right for Limited Slip? The groaning during figure 8's would indicate a problem there more than the gear change.
Old 04-12-2021, 09:34 AM   #5
BostiPB
BostiPB's Avatar
Drives: 2014 Camaro 2SS/RS
Still have the stock LSD in it?
If its only groaning on the turns, needs more friction modifier. I know on my stock diff, when I changed my gear oil out, I used some Royal Purple that had the friction modifier already in it. I still had to add more friction modifier to the Royal Purple because had the LSD groaning on tight turns.
My new Yukon 4.11 make noise, but I expected to hear some noise. Only rubber bushings I have left in the rear end and suspension are on the stock driveshaft.
2014 2SS/RS - Red Rock Metallic - Kooks Headers, Corsa Extreme, Factory Reproductions Z28 Rims, Pedders Coilovers, JDP Clutch Reservoir, Summit Racing Line Lock, GM Strut Brace, GM low profile splash guards, Roto-fab CAI, Oracle Ghosted Sidemarker Lights & Concept Mirrors, ZL1 Side Skirts, MGW Flat Stick Shifter, BMR Subframe Connectors, Eaton Truetrac, Yukon 4.11s, GForce Renegade Axles, Speedmaster79 Diff Cover, Offset Diff Bushings, Every Suspension Bushing Front & Rear Replaced with BMR Poly Bushings - 421HP 412TQ
BostiPB is offline   Reply With Quote
Old 04-12-2021, 10:25 AM   #6
Avenging Orange
I just had these done by reputable shop. They build em in house and have an exchange thing like JRE. I followed their directions and recommended gear lube (Valvoline). So, yeah, gears are new (AAM 3.91) but I don't know what else is in there or done. Yes, it's a stock carrier (just not my original). And I have all BMR bushings. Yes, I knew and expected noise. They always made a little on hard turns with OEM 3.45's. Used synthetic 75w90 gear lube....like I always have. Just wondering if a little extra noise was common for a brand new gear set.
Thanks.
Old 04-12-2021, 11:28 AM   #7
Modernmusclecar
Dont know why you guys are thinking noise is ok. Like I said my 391s made zero noise for 3 years...none. Last fall when I turned sharp it sounded like a tire rubbing. Changed out the diff oil with the proper with the modifier and now nothing.
Old 04-12-2021, 12:12 PM   #8
Avenging Orange
I guess when the people who build em for a living tell you to expect some noise.....we tend to believe rhen.
Old 04-12-2021, 01:57 PM   #9
Modernmusclecar
Well thats weird because the suspension shop that did mine told me there wont be any noise....and I guess since its been 3 years they must have been mistaken. Like you they did a swap with my tuners shop with my diff for theirs with the 391s installed. If your 345 s made noise then you may have other issues.
Old 04-12-2021, 02:36 PM   #10
gtstorey
Thanks.
Any chance you picked up the wrong Valvoline? Some of it has the LS additive, some doesn't.
Old 04-12-2021, 04:52 PM   #11
Avenging Orange
Nope, says so on the bottle.
Old 04-12-2021, 09:30 PM   #12
Avenging Orange
Thanks for your input, folks. Got it fixed. Went with my intuition and did things the way I always do it. Got rid of the crap synthetic stuff and replaced with Valvoline conventional 75w90. Nice n quiet now.
Old 04-13-2021, 05:19 PM   #13
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
AWESOME!! Good job sir. Now enjoy that new acceleration!! lol.
TSP STAGE 3 CAM,231/246 @112 LSA 614/641 LIFT, CIRCLE D 5C-4200-4500 CONVERTER,LOD INTAKE.CORSA EXHAUST. DSS 1 PC DS. PEGASUS SOLID CRADLE MOUNTS. 486RWTQ/475RWHP.LOTS MORE.
Old 04-13-2021, 06:15 PM   #14
Avenging Orange
Like a different car now.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
