03-10-2012, 04:15 PM | #1 |
Drives: 2010 Camaro SS LS3 Join Date: Sep 2010
Broke intake manifold bolt
I was doing the fuel line relocation mod today. All was going well until torqueing the intake manifold bolts. For some reason my torque wrench stopped clicking on the second bolt from the back on the drivers side. And about the time I realized something was wrong the bolt snapped.
The car is idling fine but haven't taken it out for a drive yet. What are the chances I can run without that bolt and not have problems?
She is only memory now. |
03-10-2012, 06:24 PM | #2 |
I'm not totally useless..
Personally I wouldn't risk it. But it depends on which bolt it is. If it is an end bolt chances are worse than if a center bolt which has bolts on either side supplying some torque holding value.
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
03-10-2012, 06:39 PM | #3 |
Drives: 2010 Camaro SS,2008 Hayabusa Join Date: Jun 2010
Just go get another bolt. And chances are you over torqued some of the other bolts.
Fastest camaro in OKC |
03-10-2012, 08:26 PM | #4 |
Thanks guys.
I'm not sure why it was that one bolt but the rest torqued fine. A local builder said since it wasn't an end bolt it would likely be fine. The car idlles and drive fine and the fuel trims look good. I am going to spray some carb cleaner around that area while the engine is running to check for any leaks. Fingers crossed. Even if it's good, eventually the bolt will be replaced.
03-10-2012, 09:16 PM | #5 | |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
03-11-2012, 07:21 AM | #6 |
What is connected to the back of the intake manifold? I wanted to remove it too, just out of curiousity, but something was connected that i couldn't see.
05-16-2013, 07:55 PM | #7 |
Drives: 2011 2SS/RS (M6) 427 Twin Turbo Join Date: May 2008
Brake booster hose is wrapped around another connector its a PITA to get out unless you have and extra set of hands to help you out
2011 Camaro 2SS/RS ERL 427 M6 TT -AGP Twin Turbo 55/57 .83ar | ERL 427ci | Squash Fuel System | Stainless Works Chambered 3" | Mcleod RXT | Factory Hurst Short Throw | Black Forgestar F14s | CTS V 6 Piston Brembo | VIS AMS Carbon Fiber Hood | Anvil Carbon Fiber Spoiler |
05-16-2013, 07:56 PM | #8 |
Drives: 2010 camaro ss Join Date: Nov 2012
surprised the bolt let go before the aluminum threads in the head
05-17-2013, 12:50 PM | #9 |
Drives: A Gift From My Wife Join Date: Apr 2009
True, unless the bolt was defective to begin with. -Funk
2012 Convert 2SS/RS SW/IO LS3 - Build #1081
07/21/2011 - (3800) Order produced and vehicle is being prepared for shipping. 08/09/2011 - (4200) Shipped (vehicle is shipped to the dealer or interim point of delivery). 08/16/2011 - (5000) Vehicle has been delivered to dealer. 08/19/2011 - In my possession. |
05-17-2013, 01:22 PM | #10 |
Wow old thread. I put 50k on my car since the discussion and sold it.
05-19-2013, 10:24 AM | #11 |
Drives: 79 transam with 582cid dart motor Join Date: Jun 2010
Just curious, did you ever fix the bolt, or did it run fine for another 50 k miles?
2010 Camaro (inferno orange, 2SS, RS and such) cat backs, catch can, CAI on the way 79 Transam, 582 cid dart motor 779hp 315's out back 40spline gdaxles tko tranny |
05-19-2013, 07:17 PM | #12 |
My SS was a daily driver that sometimes made multi-state trips so I was too paranoid to run without an end bolt. Chad Barton (CBI) was able to extract the recessed end of the bolt. He basically was able to weld enough tiny beads on top of each other until it was high enough to weld the top on and then back out the entire thing and install a new one. It was pretty impressive to me because it was recessed in the head enough that I wouldn't have thought it possible.
05-19-2013, 07:30 PM | #13 |
Banned
Drives: ss camaro Join Date: Jul 2012
lmao
Similar Threads | ||||
Cold Air Inductions Intake System! ADM Performance Cold Air Scoop! & Packages! | AutoAgenda | V8 Bolt-Ons & Tunes | 438 | 11-23-2013 10:49 PM |
2012 V6 C.A.I. Inc. | Camaro 3.6L Cold Air Inductions Intake System! | Plus Packages! | AutoAgenda | V6 Bolt-Ons & Tunes | 87 | 08-25-2013 05:22 PM |
Muscle Division V8 INTAKE AND PROGRAMMER MEGA SALE & POWER PACKAGES | ImportImage | V8 Bolt-Ons & Tunes | 12 | 11-06-2011 07:28 PM |
PWA "The Lounge" | DGthe3 | Off-topic Discussions | 143773 | 11-06-2010 11:00 AM |
