Old 08-25-2017, 12:07 PM   #1
Drillteamleader
Drives: 2010 2ssrs
Alignment setup for drag racing
After installing my parts i want to set up the alignment more like a straight axle would be. No camber and no toe. Will this cause any problems with bump steer in the rear?
Drillteamleader is offline   Reply With Quote
Old 08-25-2017, 01:26 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
For the rear, no camber is fine but you should have a small amount of toe in to compensate for movement in the rear suspension (arms and bushings flexing); 0.12° toe in on both sides is typical; if the wheels toe out the rear can be a little squirrely. For the front, if you don't have skinnies you can do max negative camber to simulate skinnies, and again a bit of toe in helps for dynamic toe changes while accelerating as well as helping maintain a straight path down the strip.
Overkill Tuned; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
KillboyPowerhead is offline   Reply With Quote
Old 08-25-2017, 03:14 PM   #3
Drillteamleader
Drives: 2010 2ssrs
Thanks for that.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
