09-07-2016, 03:34 AM | #1 |
Mad***der
Drives: 2010 Camaro 2SS Join Date: Aug 2016
The headaches have started!
\rant
So just got my car this last Wed, it was shipped to me from Florida after winning an Ebay bid. I looked at the pictures about 100 times before bidding on the car, living in California and with all this emissions regulations I had to make sure it was legal. So I had a dealer take a picture of the emissions sticker and it was CA compliant. Everything seem good or so I thought. Car gets here and you know I take pictures and what not, no dents or major scratches to be seen. Interior is almost perfect. One of the glass from the clusters 4 pod is broken. The Trans TEMP. No biggie I saw that on the pictures before hand ( how do you replace them ? ) and some of the speakers appear to be blown. Other than that car is solid.... .... I turn on the car and booom! sounds amazing! like too good, like a race car good. Look underneath and NO CATS! no cats! and LONG TUBE headers! How do I pass smog check in CA with no CATS? you can't. Engine codes are for the lack of cats. So unless I put the exhaust back to stock I wont be able to register it here in California. Don't know what to do... /rant On a good note, 2 confirmed kills so far. 2016 Mustang 5.0 and what I believe is a 2016 corvette with unknown mods. |
09-07-2016, 03:39 AM | #2 |
Mad***der
I don't know what mods are done to this car, my friend ( GM tech ) thinks the heads were replaced, has a mild cam and a tune. I found a switch on the center panel by were the knee sits, doesn't do anything that I can see. I don't think is for cutoffs since it's pretty much straight pipes.
09-07-2016, 05:27 AM | #3 | |
Drives: 2012 2SS/RS Join Date: Oct 2014
Buy some stock cats and put them on for the smog or some hi flow cats. It's all OBD2 scan no sniffer.
09-07-2016, 05:38 AM | #4 |
Drives: 2010 2SS/RS Inferno Orange Join Date: Mar 2013
You should be able to find a set of stock manifolds and mid pipes with factory cats pretty easily. Depending on your mechanical skills, your looking at a few hours of labor to bring it back to stock. You mention that the car has a CEL due to the headers but then mention that the car may have a tune. If it were tuned then more than likely you wouldn't be getting a CEL. They should have tuned out the back O2 sensors. Either way you'll have to clear the codes with a hand held scanner/tuner.
If the car is tuned you'll have to find someone who can flash a stock tune back into the ECU. But if you have a cam and aftermarket heads the car may not like the factory tune. Can you check with the dealership you bought the car from and possibly get a list of mods that were done to the car? I wish you the best of luck getting this all figured out.
U.S. Army Retired |
09-07-2016, 06:22 AM | #5 | |
Mad***der
NEVERMIND that previous statement, did some research and that wont work. |
09-07-2016, 06:31 AM | #6 |
Drives: 2013 HWSE Indy Festial #26 Join Date: Mar 2011
OP, You came to the right place for advice. I don't know if it will solve your problem, but check out this guy's ad here:
http://www.camaro5.com/forums/showthread.php?t=465088 Good luck. I hope CA emission standards never make it to the rest of the country!
There are only so many days in your lifetime. So get out and drive your Camaro...
Dan |
09-07-2016, 08:13 AM | #7 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
Does CA do a visual? If not get a tune from RDP dyno Steve! His tune will clear all codes, pass all OBDII tests(per Steve) AND turn what you think is a fast car into a completely different animal....
F. Weller btw - I have the stock exhaust manifold and cats(WITH O2's) from my 2010 layin on the garage floor gettin ready to toss...if you need them let me know....s/h plus a little scratch to make it worth my time lol
09-07-2016, 04:15 PM | #8 |
you need to know what was done to the car. if you have a cam or heads you kneed to know what ones. If you have a local tuner take it there.
09-07-2016, 06:22 PM | #9 |
Mad***der
My first search from Google came out that he is getting sued ... anyways I got the car smogged and passed with flying colors. Its always nice to know someone who knows someone who can get you a number to call this other person who emails you an address where you can meet someone who tells you where to take it to.
09-07-2016, 06:28 PM | #10 | |
Drives: 2014 2SS M6 "CHRISTINE" Join Date: Mar 2014
"But, House Mormont remembers. The North remembers! We know no King but the King of the North whose name is Stark. I don't care if he's a bastard. Ned Stark's blood runs through his veins. He's my king–from this day until his last day."
Mods: ARH headers and hi flow cats, VMAX ported throttle body, CAI air intake, Slowhawk Performance tuning |
09-07-2016, 06:49 PM | #11 |
I talked to a smog shop today he said a tuner can tune the car so the code for the cats shows up and passes. I am in the same boat I got to get mine smogged as well.
09-08-2016, 08:37 AM | #12 |
Drives: 2015 2LT RS Join Date: Feb 2015
Register it in a different state that does not have such high emission standards. Maybe a friend or family member lives in a no-emission test state? Just a suggestion. Don't know the legality of that, so if it is illegal, I never suggested doing such......LOL!
It is what it is!
09-08-2016, 09:38 AM | #13 | |
Mad***der
I got it smogged already, just need to find a tuna guy |
09-08-2016, 09:43 AM | #14 |
Drives: 2011 2SS Join Date: Mar 2015
I'm surprised you passed. Long tubes are illegal here so you won't pass the visual test. Weird. You must know a guy
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears |
