11-05-2017, 06:44 AM | #1 |
Drives: '13 LS, '09 Forester, '11 HD SGlide Join Date: Jul 2017
So....about using a catch can.....
Changed the oil this weekend at under 11k (bought the car with 5400 on it).
Didn’t see the catch can until today (for some reason) This is what it looked like (when I got it loose). Yikes was the word I used.
2013 Chevrolet Camaro LS - M6
2011 Harley Davidson Street Glide 2009 Subaru Forester - M5 |
11-05-2017, 07:02 AM | #2 |
Banned
Drives: Camaro Join Date: Mar 2013
I've had one on my car for nearly a year. Not a drop in it yet.
11-05-2017, 07:21 AM | #3 |
Drives: 2010 Camaro Join Date: May 2014
11-05-2017, 08:12 AM | #4 |
old school chevy rodder
I would say the same for the guy without a drop , must not drive it or its not installed correctly, for the LS driver your should check your can more often as the v-6 is noted for more blow by and yup that would be in your intake tract if you did not have it.......For a v-8 my normal amount is about a ounce every couple thousand miles running correct 5w30.
11-05-2017, 08:15 AM | #5 | |
Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
Spike III Build 2011 IBM 1SS/RS [COTW 6/25/12]
11-05-2017, 09:27 AM | #6 |
Found this in a post in the engine section dealing with the v-6 and its catch can results from Elite Engineering, I use them....
A good catchcan will trap far more than just oil, infact our E2 and E2-X will trap nearly all compounds that are part of the crankcase vapors, and here is an example of what a sample drain consists of: 70% is acidic water (the sulfuric acid and other acids formed mix with the water and don;t separate once mixed). 23% is raw fuel and other volatile chemicals. 7% is oil, and dirty oil saturated with abrasive particulate matter such as carbon, soot, and ash. This is a GDI engine drain. A LS port injected will not have as much fuel as GDI engines have many times the raw fuel pushed past the rings.
11-05-2017, 09:40 AM | #7 |
Drives: 2012 2SS Victory Red with white st Join Date: Jun 2016
Been seeing the good, bad, and ugly about using a catch can. I got one Friday and will be putting it on shortly. Raining today. It is almos one of those must have items for a Camaro
11-05-2017, 10:15 AM | #8 |
Drives: 2010 Camaro SS 2SS Join Date: Jul 2017
11-05-2017, 12:14 PM | #9 |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
I empty mine at every oil change, usually about half full. I put a RX on at my first oil change, it didn’t catch much, switched to an Elite after a year and it catches twice as much and is eaiser to empty.
The Bird is the word! |
11-05-2017, 01:46 PM | #10 |
I ordered the mishimoto and am awaiting for it's arrival. Will have it on by weekend.
Custom TSP Stage 2 Cam/GPI intake Ported Rod Mod /VARARAM CAI/Mishimoto Catch Can/1 LE front & rear sway bars/ engine cover/fuse box custom painted, strut tower brace, Texas Speed LT, Hi Flo Cats, Magnum Tru-X pipe, NGK Spark Plugs, PCM Spark Plug Wire, Painted Calipers, CF Spoiler w/wicker bill. |
11-05-2017, 02:29 PM | #11 |
Banned
11-05-2017, 08:10 PM | #12 |
Drives: Classy Join Date: Apr 2017
jrhagen, there is no way if the can is installed correctly that you would not have any oil in it, impossible. If you have no oil in it the installation or parts are incorrect. What can do you have and do you have a picture of the install ?
11-06-2017, 05:41 AM | #13 |
Account not blocked
I agree
11-06-2017, 10:34 AM | #14 |
Thanks. I’m thinking the car sat for a while before it was sold last year. First time I noticed it when I changed the oil (it was staring me in the face when I tried to move the cover to get at the filter cover batter).
It was fairly viscous (like oil), but it may never have been opened since the install (it was on super tight) Now I’ll check it more.
