Old 07-03-2018, 07:23 PM   #1
who-dat
Drives: 2011 1ss
Wiring Harness Connector
Headlight will stop working on the passenger side every now and then. I'm using gen5diy harness for nonrs to rs lights. Pulled the main harness connector and noticed this attached in picture. This is a problem, right?
Possible to fix this or how can I go about replacing it?
who-dat is offline   Reply With Quote
Old 07-04-2018, 12:13 AM   #2
blake-b
blake-b's Avatar
Drives: 2009 ZR1
You can buy just a replacement pigtail for it. Cut the old one off and connect the new one.
https://www.ebay.com/itm/GT-150-Seri...0AAOSwXaRaKlxO
Part number is 15326835
If you find one with all the wires the same color as in the ebay link, obviously pay close attention so you connect the wires correctly.
Double check the your harness to make sure the wire colors are the same as in the attached diagram to make sure I inserted the right connector pictures.
Old 07-04-2018, 09:02 AM   #3
who-dat
Drives: 2011 1ss
Thanks for this info!!!!!!!
