Old 07-13-2018, 08:19 PM   #1
Witt51
Drives: Black 2ss
Engine install
I don't know if this is right spot. I'm getting ready to install my engine and decided to go from the bottom. My question is do I have to disconnect the A/c system and the power steering pump. I have seen so many different ways of doing and mostly they are for f-body. I took it out from the top but I want to get everything together and just stick it all in at once. Any advice, DIY or videos.
I thought this would get the most views posted here
Sent from my SM-N950U using Tapatalk
Witt51 is offline   Reply With Quote
Old 07-14-2018, 12:32 PM   #2
Witt51
Drives: Black 2ss
No one has pulled the engine out of the 5th gen from the bottom?
Old 07-14-2018, 12:36 PM   #3
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
Drop the cradle , or pull it from the top . In the long run your better off pulling it from the top .
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 07-14-2018, 12:37 PM   #4
Witt51
Drives: Black 2ss
Delete
Old 07-14-2018, 12:52 PM   #5
Witt51
Drives: Black 2ss
I lost my partner that was helping install it and after looking around a bit I have noticed alot of people can do it with one person going through bottom. Of course that's f-body. I know most speed shops go from bottom also. I have the engine built up almost all the way besides the intake. Looking in the engine bay it just looks so my much easier dropping the k member but I know I'm probably missing something. Lol
Old 07-14-2018, 03:02 PM   #6
Synner
Drives: cars
Just zip tie the a/c unit out of the way after unbolting it so you doin't discharge it. Everything steering and hydraulic drops down except for the cooler in condenser bottom so you lose fluid but not a big deal and you will refill and bleed when reconnected.
Old 07-14-2018, 03:07 PM   #7
Witt51
Drives: Black 2ss
I was thinking the power steering unit was also connected to evaporator also or atleast there was a line going to on from the steering rack. I will need to take a Pic when I get home. This can save such a headache
Old 07-14-2018, 03:44 PM   #8
Witt51
Drives: Black 2ss
This the line I'm wondering about. Goes to steering rack.
Old 07-14-2018, 04:40 PM   #9
blake-b
blake-b's Avatar
Drives: 2009 ZR1
The power steering is connector to the AC condensor on both sides (one nipple each side)
Old 07-14-2018, 04:54 PM   #10
Witt51
Drives: Black 2ss
Will that require me to just bleed the power steering system that's all.? Sorry about the question but trying to get away with not doing more crap than need to.
Old 07-14-2018, 04:55 PM   #11
Witt51
Drives: Black 2ss
Power steering should be easy to bleed. Leave the cap off and turn the wheel back and forth?
Old 07-14-2018, 05:40 PM   #12
Witt51
Drives: Black 2ss
Thanks for the help. Got it figured out. Saved me a lot of stress.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
