12-15-2018, 08:49 AM | #1 |
Drives: 10 Procharged SS Join Date: Oct 2009
ECM been changed? Odo reading ---
Is there a way to tell if the ECM in my car isn't the one that came with it from the factory?
Im chasing an issue with my odometer and tripometer not reading anything (---). I was thinking it was the bcm but its been flashed and still no odometer reading. Any ideas or what else to check for?
10 Camaro: Built 376, LSA Heads, BTR valve train and Stage III Camshaft. F1A 12 Rib-3.75 pulley (17psi), Squash Dual Fuel System with Return (Dual Walbro 450LPH on a Hobbs Switch), Aeromotive regulator, Holley Fuel Rails, ID1300's. RMVB 4L80, 4K Stall, and Trans-brake. 9" IRS, 3.50 gears with a full spool
12-21-2018, 12:41 AM | #2 |
Drives: 2023 SS 1LE 10SPD/2015 SS 427 Man Join Date: Aug 2015
was everything working and then just quit? a little background would help
12-24-2018, 09:18 AM | #3 | |
Everything else works fine tho, which is the confusing part for me.
