SDTW Custom Wheels & Tires
Old 11-29-2017, 05:17 PM   #1
adbarnett5
adbarnett5's Avatar
Drives: 2011 RS LT
Catalytic Converter Below Threshold
https://www.google.com/search?q=cata...hrome&ie=UTF-8
So 2 times now I have had this code pulled from my car. The check engine light comes on every now and then, then it goes off, and then comes on. What is the best solution for this?
Car is slightly over 100k times.
adbarnett5 is offline   Reply With Quote
Old 11-29-2017, 05:18 PM   #2
JerTM
JerTM's Avatar
Drives: 2011 2SS/RS M6
Replace the cats, or tune it out. That's the only options.
Originally Posted by Zezima View Post
(exaggerated example) omg they said my car is slow cause its a v6 isn't this surreal
followed by empathetic but also some genuine comments but mostly nut sucking the v6 owner
JerTM is offline   Reply With Quote
Old 11-29-2017, 05:30 PM   #3
adbarnett5
adbarnett5's Avatar
Drives: 2011 RS LT
I just looked down there, they look like they are just normal wear and tear from the outside. Don't look burned up or black.
I been reading about it, seems sometimes the sensors just go bad?
Old 11-29-2017, 08:46 PM   #4
JerTM
JerTM's Avatar
Below threshold isn't something you can see. They are no longer functioning to a set standard. You can try changing all the sensors you want, but in my experience it doesn't fix a bad cat. I've worked for GM over 10 years fwiw.
Old 11-29-2017, 08:55 PM   #5
adbarnett5
adbarnett5's Avatar
Drives: 2011 RS LT
Thanks, yea... they are 700$ a piece to replace, so you can understand my hesitancy.
Old 11-29-2017, 09:13 PM   #6
JOURDAN
Drives: 2010 Camaro SS 2SS
You remember the ATM scam that was going on a while back.... They would put a FAKE face on it and you would input credit card and they would capture...
So.... How about a FAKE OBDII port, you drive up to DEQ, they plug into your car, and your small micro processor provides all the FAKE data to DEQ and you
PASS,
Be simple really, you could just make a recording and play it back....
hum... food for thought.
JOURDAN is offline   Reply With Quote
Old 11-29-2017, 09:28 PM   #7
JerTM
JerTM's Avatar
I get it, it sucks. The 3.6 is awful hard on them. I've changed quite a few.
Old 11-30-2017, 06:59 AM   #8
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
shop around.....
2013 2SS/RS LS3 M6 ,CRT, NPP, Forged 428 ls3 stroker, GMPP ported heads, Katech chain, Mast windage, Cam Motion Cam, trunnion upgrade, Stainless Power headers HFC, CAI w/kit, Vmax PTD, Fluidampr25% udp, LPW diff cover, BMR strut brace,trailing arms, toes, bushings, Rocket racing wheels,Toyo Proxes 4+, elite catch can, clutch reservoir, dash/body LED, DRL rewire, Sparks billet badges, Forza 3way, tint, MRT louvers, ZL1 spoiler, MGW short throw, Monster dual LT1S clutch, bleeder, support, high vol pump, Speed hut shift light, ACC flames stripes, Driven ls30 oil, NGK TR6IX , Granatelli wires.
Old 11-30-2017, 07:00 AM   #9
Spurshot
Drives: 2014 2SS blue
Cats go bad eventually. 100k is not unusual for that. Agree, they are pricey.
Try this
http://www.discountcatalyticconverte...6%20Cyl%203.6L
Spurshot is offline   Reply With Quote
Old 11-30-2017, 07:44 AM   #10
adbarnett5
adbarnett5's Avatar
Drives: 2011 RS LT
PASS,
Right, u always think that when you go to any car place, but thing is I have had it read by 2 different scanners at 2 points in time. Both threw same code.
Old 11-30-2017, 09:09 AM   #11
JerTM
JerTM's Avatar
He's suggesting that you try to cheat any emissions testing you might have with a dummy port. Nice thought, but it's not exactly that easy.
Old 11-30-2017, 09:25 AM   #12
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2013 1LS, 1968 Camaro SS, 2000 MCSS
PASS,
Not hard with a tune... if all they are doing is pulling the reported codes and failing you for a CEL, you just tell the PCM to not report those codes and you'll pass.
2013 Camaro 1LS - Daily Driver
1968 Camaro SS - Show Car
2000 Monte Carlo SS - Paxton Novi Supercharged Project
2018 Regal TourX - Because we need at least ONE family car
ChibiBlackSheep is offline   Reply With Quote
Old 11-30-2017, 11:56 AM   #13
Dusman23
Dusman23's Avatar
Drives: 2010 Black Camaro RS Package
I've had the same thing going on with my car since I got a new cat-back exhaust. Best thing I've seen is just to get a tune to ignore the O2 sensors. Cheapest way to do it too
Dusman23 is offline   Reply With Quote
Old 11-30-2017, 02:04 PM   #14
Scalded Dog
Scalded Dog's Avatar
Drives: 2011 1LT
PASS,
I think that's a really great idea... actually building and programming one, however, might be tough. But, there would damn sure be a market for it, not only from owners of cars that throw codes for expensive repairs, but also for modified vehicles.
Scalded Dog is offline   Reply With Quote
