Old 07-14-2020, 02:53 PM   #1
GhostOutlaw
Drives: Black 2011 2LT/RS
Constant P0420/P0430
I've replaced both cats, all the sensors, I use top tier fuel, there's a catch can in place and I STILL ****ING THROW P0420/P0430 randomly. I clear it and it usually goes away until the next fill up.
I'm at the point I'm thinking a cat delete, both myself and my mechanic don't know what to do.
Anyone else have this?
GhostOutlaw is offline   Reply With Quote
Old 07-14-2020, 03:20 PM   #2
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
Headers? If so, it's in the tune. What brand cats and sensors? Those can throw codes as well.
JB'sZL1 is offline   Reply With Quote
Old 07-14-2020, 03:31 PM   #3
GhostOutlaw
OEM replacements. Stock headers.
Old 07-15-2020, 06:18 AM   #4
fhrex
fhrex's Avatar
Drives: 2011 Camaro 2LT/RS
mine threw a P0420 about 8 months ago, cleared code, never came back....knock on wood...
fhrex is offline   Reply With Quote
Old 07-15-2020, 06:11 PM   #5
'10CamaroDude
Drives: 2010 Camaro LS
Same here, I had to add extenders, and one spacer:
I had P0430, continually, it was because #1, it was a Bosch sensor, and you have
to use FACTORY ones. #2, the dopes drilled holes in the tip of the sensor. These
idiots had the car for TEN weeks. I fixed in in a matter of minutes, once I put the
OE sensor back in, what they could not do in 2.5 months!
So, I had to go back to factory on that side, used an extender, then added an anti-fouler, and
it went away. I then replaced the accelerator pedal assembly, and then got the P0420 and I
wasn't with two anti-foulers on it. So I added the extender, and one anti-fouler to that, and
everything has been good since. These cars are very sensitive...
P0430 and P0420 means the primary cats are flowing too fast. Usually with
replacing them with non OEM cats, they're more hi-flow.
Nothing monitors the secondary cats, so mine are out. However, removing them may
also increase flow, thus the codes.
Go to your local parts store and add ONE of these to each side:
Wait and see if the codes come back. IF they do, put ANOTHER one
on the effected side(s).
I ended up having to go three lengths deep on each side, one long extender,
and one anti-fouler.
'10CamaroDude is offline   Reply With Quote
Old 07-18-2020, 07:05 PM   #6
GhostOutlaw
So, my issue with using the foulers is that it doesn't fix the actual cause of the problem. It just makes it so that the sensors can't detect the flow as well.
I'd rather fix the actual problem.
Old 07-29-2020, 05:16 AM   #7
'10CamaroDude
Then you will be spending $300+ per side for factory down-pipes, which
has the primary and secondary cats -vs- 5% of that on spacers.
There is no REAL problem, it means the primary cats are flowing too fast.
That would be the SAME as if you bought hi-flow cats to replace your factory
ones. You'd still need the spacers on each side, because the car thinks
the primary cats are bad, and allowing too much flow, but you have new
hi-flows on, like MINE, well, now minus the secondary cats. I am also
averaging 25.5 MPG without the secondaries.
As long as you do not have any UPSTREAM codes, you're fine. That will
effect how the car runs. You can run with P0430/20 codes and it will
run just fine.
The point also, is this shows just how much a a fraud Emissions testing
actually is. If you can gut your cats, and put spacers on the downstream
sensors, for no CEL, it's just a racket.
Old 09-12-2020, 03:52 PM   #8
GhostOutlaw
run just fine.
Delete the cats! Got it!
Old 09-12-2020, 06:56 PM   #9
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 NPP BRM
run just fine.
What he said! If you don't want to put on extenders then pay thru your ass for nothing or ... sell the car and drive a Prius. I’m just being a wize ass. Seriously those codes just mean the cats are functioning/filtering emissions at a variance to specs. They is nothing wrong with your engine.
camguynj is offline   Reply With Quote
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
